Discuss sanity check for electrical services in the UK Electrical Forum area at ElectriciansForums.net
Hello all, first post but have enjoyed the forum for a while..
I am in Bristol and recently had an electrician do some work on my house - I want to sanity check the way this guy operated.
He did some tasks satisfactorily: Changed a room to a ring circuit, hooked up a second light switch for overheads, sorted out undercabinet lighting. Was about 2 man-days. For this he charged me ÂŁ 1300. Is that a reasonable amount.. ÂŁ80ish/hr?
Second question: there was a wall switch PIR in the hallway he had a look at (was previously installed and stopped working during construction). He said it was wired all wrong, the earth was being used as the negative, and it was super dangerous. He took the PIR off the wall, and left the wires hanging out the wall with waygo connectors on the ends, then left it like that. Is that allowed?! I've been scared to do anything with it.
The last question: he said my fusebox was not up to regulation, after he had done all the work (ring circuit, etc). Said it would be a days worth of work and should be done, due to reg changes. I did not catch exactly what he said was needed but when I bought my house in 2011, this was not flagged as an issue. Is this typical? and if yes, what's a days work roughly go for with an electrician?
Thank you in advance!
Travis
Yes the PIR was wired incorrectly but super dangerous probably not, removing it and fitting unenclosed Wago connectors has left it more dangerous than it was in the first place.
There is no requirement to upgrade your consumer unit so it meets current Regulations however a picture of it can help us to advise.
This I'm curious about.
Why was the room circuit changed to a ring?
ÂŁ1300 seems a lot to me. Where the undercabinet lights gold or something.
One important question is: Did you get a Minor Electrical Installation Works Certificate for the work done.
unless the room he changed to a ring probalby lift up floor boards raggle walls, run new wiring back to fusebox . maybe its a 5 bed house ---- knows. etc make wiring good and everything that goes with it. that mite have been the bulk of the cost. leaving exposed wagos not good unless the house is derelict or no one living there atm or power been isolated etc. fusebox cant commect unless see what it looks like , if added new ring will be on rcd side . if no rcd somtimes its more economical to replace full board. as usual 2 sides to every storey. if thought the price was off should get a couple more quotes no harm done.
Sorry for the slow response.. forum notification updates were off
I thought it felt more dangerous too. Is this allowed by all the guilds and organizations electricians belong to?
I'll try to send a pic of the Consumer Unit. I wish ĂŤ had asked more questions when he was through..
Why a ring?
So there was a lot of kit plugged into the sockets in the room.. When I looked under the floorboards, the wire supplying the room had apparently gotten quite hot and had melted into the styrofoam insulation under my floor
I am not sure if ring was required, but it seemed like the room was in-adequately supplied. What do you think?
Re 1300... It felt like a lot too!
I want to challenge this bill to be honest.
Was I supposed to get a Minor Electrical Installation Works Certificate? is this something I should request?
Can you explain more?
i smell rip off. 2 days about ÂŁ500 - ÂŁ600. add materials used, probably about ÂŁ100 -150. does this spark drive a Transit or a Porsche?
I feel super ripped off. The contractor who organized the work said it was GBP 1300 and he paid the spark.
The contractor DEFINITELY was taking the ---- on several amounts he tried to charge, so I don't really believe him
Trying to navigate what to do now.
The spark left and said that my consumer box was not up to regulations and he wasn't even supposed to work on the house without having had upgraded it. I wonder if there's any leverage I have with that fact (if it's true)
Also, the fact that this guy who has to take multiple tests every year to be certified has left dangerous wires just hanging out of my wall ... a total sloppy mess.
Do you think I have leverage here?
Thanks for the reply
He may have lifted a board or two. he did not cut walls. he did run wires back to fusebox through 1 room.
It's not a five bedroom.. he went from a living room (the new ring circuit room) through a hallway to the box.
house is not derelict and I was living there. I thought WTF is this guy doing, he left the wall socket in worse shape than when he arrived.
Is this allowed for a certified electrician spark?
I'm going to take pics of the consumer box.. maybe you guys can give your thoughts on it.
You should definitely have got a certificate for the work he has done.
Yes mate, you should have definitely got a Minor Electrical Installation Works Certificate.
Yes, for the price of ÂŁ1,300 I would request that they finish the job off by giving you the cert. The job is not finished until you receive it.
Why a ring?
Then it sounds like the original cable supplying the room was not adequate for the breaker size and installation method.
Lets hope that this electrician has allowed for the insulation under the floor and sized accordingly.
Could you explain what the certificate is, why he should have given it to me, etc?
Is this something that he may say: No, I don't have a certificate for you and now that he's paid, he won't give it to me?
See post 11 from Spoon.
Just to clarify the cert. This is pinched from the electrical regs.
So I wanted to share an update... I've been in touch with the electrician and he says he won't give me a certificate of electrical work done. He said the wiring is a mess ( which to be clear, he left it a mess ... then the contractor who subcontracted him demanded payment for his work )
This appears like he doesn't want his name attached to what he's done at my house... or perhaps there's something wrong with my electrical system where he shouldn't have been working on it in the first place. I am feeling quite jerked around by this whole experience
I could seriously use some advice here from The Forum: how should I proceed?
When I get back in January the first thing I'm going to do is schedule another electrician to have a look at the work done.
I guess I should probably have a chat with citizens advice as well.
Any thoughts please?
Drop me a DM - I've got a reason to come up to Bristol in Jan at some point (I'm south Somerset) and whilst I don't tend to do domestic anymore I'd be happy to look it over and advise if you'd like.
Money wise you're probably on to a looser if you've paid up already to a third party, but the work absolutely needs certifying - even if the cert is 30 pages of observations about issues.
Me personally I name and shame these people. Put it out on social media in your area that he's rough and doesn't give the required documentation.
The money is probably the contractor taking ÂŁ500 or something and giving the rest to the spark.
I've said this before on here and got ripped for it but i'm going to say it again: if you want to get what you pay for never ever let a builder or other contractor arrange electrical work for you. It will rocket the price and they're nothing but middlemen. In this day and age you can go straight to a scheme provider and find your own spark and get him to quote direct.
Just because a member is part of a scheme does NOT mean he is any good or will do a good job!! Many people get caught out like this.
Mate, that would be really amazing and I'd be happy to pay for your time. Will send you a DM
Regarding the futility about the payment made already - not it's not really about the money. I just want a certification if that's what'd normally done. And a clearly documented account of what he did under my hardwood floor, for anything in the future that comes up.
Reply to sanity check for electrical services in the UK Electrical Forum area at ElectriciansForums.net
This drives me round the twist, the client tells you what they want, kind of. you do the work the way the client asks you to and then when its all...
I'm planning a replacement for my existing domestic CU and would like to have it sanity checked before I get an electrician involved. The main...
4K
Hello, you all helped me out recently when we had a water leak (mostly in kitchen ceiling), and my landlord's contractor was saying the household...
I had Scottish Power moving a supply this morning from one building to another so an extension could be built. I had everything ready for them...
