Discuss Screwing a light switch back on and I assume I hit a live wire? in the Electrical Engineering Chat area at ElectriciansForums.net
I was screwing a lightswitch back into the wall when suddenly a bang and the lights tripped, I assume I hit a live wire? Can anyone shed some light on what happened?
Was the switch in question, attached to any sort of back box, or was a back box used? if not, and you tried screwing the switch directly into the building fabric the connections may have become in contact with some damp brickwork or plaster, without actually seeing what has been attempted, it's hard to say exactly what you have done, can you post a picture of the finished work or your attempt at it? this may highlight the problem.
I never touched any wiring whatsoever the lightswitch faceplate in question was simply unscrewed and rescrewed into the wall, when screwing the left hand side screw in there was a flash and a little pop a similar to the sound of a lightbulb blowing and then all the lights cut off, the lightswitch in question was off at the time also just for added information (tried to upload a pic but got the error the uploaded file was not an image as expected)
Turn the power off (at the fuse box / consumer unit), remove the switch from the wall, and look for the flashover marks where you have either damaged a cable with a screw, or crushed a cable, or a cable has come loose and shorted somewhere. Correct the problem.
Hi,unless you have bluetooth connection to your fuses....this is not the case.
You may have damage to assess and correct,which will need the attention of a trained person.
Reply to Screwing a light switch back on and I assume I hit a live wire? in the Electrical Engineering Chat area at ElectriciansForums.net
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
I'm installing smart modules in my light switches which means I need to replace the existing 25mm back boxes with 47mm ones. Downstairs all walls...
Hi all, I'm wondering if it's permitted to replace an outside wall light myself if I use the existing wiring from the old light. In theory I just...
can anyone please advise on where the wires go? My electrician installed a new cable ready for when I bought a security light. The cable as shown...
