Discuss shielded cable to extend a thermistor on hot water tank in the UK Electrical Forum area at ElectriciansForums.net
A
ab1978
hi
can anyone help me with above. need to extend a thermistor on a hot water cyclinder, it needs to be shielded cable but can't find anywhere that sells it even on line.
Your Google must be playing up then.
What cable have you been trying to search for?
Exactly what cable does the thermistor manufacturer recommend?
Reply to shielded cable to extend a thermistor on hot water tank in the UK Electrical Forum area at ElectriciansForums.net
Yesterday moved my Mum into her new bungalow. The Hortsmann had been off for a few months I suspect. The boost worked, but nothing happened...
Need help with a quote here. I’m wanting some sound advice. Was called out to the hot water not working so repaired the issue within the panel...
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi I am seeking help and best practices to achieve below tasks. I am not across regulations hence will appreciate best approach to achieve below...
