Discuss Siemens Reversing the direction of rotation of the DC motor in the UK Electrical Forum area at ElectriciansForums.net
Hello everyone. I have 1 Siemens "1GG6164-0JH40-6VV5-Z" Model DC Motor. It works in 2 phases.
What should I do to reverse the rotation direction of this motor?
I have marked the B1 and B2 Terminals in the Photo below. B1 and B2 are phase ends.
Normally with a dc motor the terminals would be marked A1 and A2 (armature)
also sometimes F1 and F2 (field) will be there too.
to reverse direction, swap the armature polarity, leave the field alone.
Thank you. In the electrical project to which the motor was connected, terminals were marked as B1 and B2. As for what you said, can you explain a little more? Since I don't speak English, the translation was insufficient. :)
Reply to Siemens Reversing the direction of rotation of the DC motor in the UK Electrical Forum area at ElectriciansForums.net
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
Hi all I have a small DC motor that I pulled off from an ABS car module and need help identifying some parts in order to hopefully rebuild it. 1...
Hello, I wired a DPDT switch to my sunroof 12v DC motor. It was working ok and I was able to reverse the polarity of the motor to open and close...
Hi I'm having a problem with a 20 HP pump motor from a hydraulic press to try molds. When we energized the machine, it starts with star...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
