Discuss Single Oven / Induction hob diversity in the UK Electrical Forum area at ElectriciansForums.net
Gringoking88
Hi all,
I have been asked to install an induction hob to an existing circuit on a 32amp mcb. The oven is a Siemens HB13NB521B rated at 20amp, the hob is a samsung NZ64H37070K rated at 32amp.
My friend is telling me that he has been told by "the man in the shop" he can run both on the one circuit. I dont believe this to be correct even with diversity.
I believe he needs to run a new circuit from his fuse board for the induction hob
Can you please help clarify if I am right or just plain stupid???
If I am stupid please be nice lol.
Many thanks,
Martin
be fine on the one 32A circuit. 6.0mm cable. allowing for diversity, the design current for both oven and hob together is 23A (28A if the cooker isolator has a 1363 socket outlet).
Reply to Single Oven / Induction hob diversity in the UK Electrical Forum area at ElectriciansForums.net
Evening all, I'm upgrading my kitchen electrics replacing the current gas hob for an induction hob. The oven was previously plugged into the...
Hi all, I'm getting a 32a induction hob and a 13a oven installed as part of a kitchen refurb. The existing cooker circuit is 6mm protected by a...
Hello, I’ve got an issue driving me crazy and can’t get anyone to figure it out as it’s not their issue. We had a new extension, single rear...
Hello I have two new appliances Electric oven rated at 3.95 KW Induction hob rated at 7.2 KW total of 11.15 KW Currently it is on its own...
4K
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
