Discuss Small indicator light inside junction box? in the UK Electrical Forum area at ElectriciansForums.net
Moved into an older Lake House in Morristown, NJ. Trying to figure out what this lightbulb inside the juntion box is all about. Anybody know what this type of switch/indicator light was used for back in the day?
Can the light be seen when the front plate is over the switch?
Is the light controlled by that switch and does that switch control any other lights?
Would that light be On when the switch is in the normal Off position?
Is the switch inside or outside the house?
I can only think it's there to show where the switch is
if it's wired directly across the switch, it's a locator for the switch. (light on when switch is off).
This is a lightbulb that would tell you if something is on, (usually an outside light or boiler/heater power). The cover plate would have had an opaque, colored or clear plastic over that space. The space where the toggle or push button would go, a push-in piece would be there. So when it's lit, you could see it.
We have lighted switches now.
Looks like there's still old BX or knob/tube wire still attached. Judging from the box too, could be from the 1940's or 50's
Reply to Small indicator light inside junction box? in the UK Electrical Forum area at ElectriciansForums.net
Hello, First of all, thank you in advance for any helpful insights posted in response to my question. I have just moved into a new home. With...
Good day. Is there something wrong with this junction box (code violation) for a wall fixture? It is secured to studs. Old construction. Need it...
I bought this house a couple months ago. It was built in 1952 (same as me) but has been rewired with yellow 12 awg Romex dated 2007. Looks like a...
I am connecting a manual transfer switch to a subpanel. In order to minimize drywall work, I am mounting the transfer switch to the surface of the...
