Discuss Smoke Alarms? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
S
Stever_777
Hi guys, I need to know if it is now compulsory to install a mains fed smoke alarm in a new kitchen and diner extension area and if so what about the existing installation?
is that mains fed murdoch
Hi,
You can wire them from a local, generaly used lighting circuit as long as it has a means of isolating the smokes without interupting the lights. If all the circuits are RCD protected there is an advantage in supplying the smokes from a regularly used lighting circuit.
page 65 & 66 OSG.
Jay
Reply to Smoke Alarms? in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I'm about to order this wired smoke alarm system as it can network but I just went to see how my existing fire alarms are hooked up and there...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
