Discuss Socket in the UK Electrical Forum area at ElectriciansForums.net
P
PeterPan27
Just a quick question..
Just wondering, if was to replace a single socket that isnt working for a double socket, the cable are too short, are we allowed just to extend the cables with a connector block in the socket?
Sorry if daft question
no...crimp them peter...you need red crimps for the CPC and blue crimps for your live conductors (assuming its 2.5/1.5 that is)...
I got both mine off ebay a fair few years back at a really good price.
They were probably knicked from the factory, but my moral standpoint is generally quite low!
heres a `bosom buddy` for you then:
i've got a note from me mam. been sorting the tip that i call a van out.
Connector blocks? Wagos? Crimp n shrink? Crikey guys where are your cost controls? This problem is nothing that a good old fashioned tape joint won't sort. Yeeeeeeehaaaaaaaa!!
We are into Never Never Land, aren't we .
Cowboy.. I mean charging customers for tape... Its concealed behind the faceplate.. Tut Tut
Totally agree with Glenn, however you could try to gain some slack, if it is under capping you may pull a few inches up or down depending on where the cables come from of course, give it a try first :wink_smile: and don't forget to do a loop test after haha
Reply to Socket in the UK Electrical Forum area at ElectriciansForums.net
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Hi All, As a householder I'm keen to add a double socket further along a wall to extend access in a different corner of the room. I'm connecting...
Double wall socket switch won't switch off. It just flips back to on. The left side one is fine. It used to do this 3 years ago then was working...
Hi all. I'm going to replace some sockets during a routine redecoration of our lounge including replacing some singles with doubles with USB...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
