Discuss Spot Light / Downlighters Installation?? in the DIY Electrical Advice area at ElectriciansForums.net
G
golding181419
Hello all, I have got quite a good understanding about electrical installations but have never installed Downlighters? I'm doing a job on my own small living room and want to install new LED downlights; the room currently has a normal ceiling rose in the middle of it and I would like to install 6 spots I have access through the floor boards upstairs to give you an idea. The main thing is I don't understand how the wiring works?? Is there any one that can explain to me the steps I need to take in the wiring process please? e.g. size and type of cable and if junction or chock boxes are used in the installation.. Also if someone knows a handy video or diagram of a step by step process that would be totally awesome!! Best Regards Chris
Downlights can be difficult to install especially on getting the spacing of the holes right.
It may be easiest for you to look for a few websites that explain the process as it can be quite in depth.
Make sure any junction boxes you use to connect the downlights can be removed from the downlight holes for future maintenance.
Read the instructions on the downlights that detail the spaces needed either side and above the downlight and ensure you have enough space.
I would also recommend planning on being able to repair the ceiling once you have a hole in the wrong place, e.g. just beside a joist, very easy to do.
I hope your thanks post from the OP is in the lists of posts that the Mods have to check...
why fit separate transformers/drivers, when GU10 fittings don't use them?
Reply to Spot Light / Downlighters Installation?? in the DIY Electrical Advice area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Hi all, DIY'er here looking for a bit of advice so please go easy on me. In my dining room there is an existing single pendant and i would like...
Hello, Looking for DIY electrical advice. I have 7 x spots, and each are fitted with 1 x T&E connector block fitting [see photo]. In the past...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hello, We changed plans with lighting in one zone. Now instead of 4 downlights (square shape of 1400mm side) we want a chandelier. Since...
