Discuss Strip Light Installation. in the Canada area at ElectriciansForums.net
A
Aerlingus
Anyone help?
I am fitting four Batten strip lights using plug in roses. Do you control the on/off with a one way switch fed to the first light fitting?
Reply to Strip Light Installation. in the Canada area at ElectriciansForums.net
I have a strip light in the kitchen operated from a single switch. I want to replace it with a straight bar 4 spot array. There are three supply...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
