Discuss Supplementary Bonding - How was it wired? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Midwest
Alot of the properties I work in, were built when the 16th Edit ruled, most with no RCD's for bathroom lighting. Majority have evidence of supplementary bonding, clamps & earth wires on basin pipework, rads etc, or in immersion heater cupboards. However, some have no sign of that. Now I've read reg 701.415.2 & 415.2.2, so you can test for the effectivness of the earthing, but I never worked under the 16th Edit, so what should I expect to see. I've mentioned earth clamps etc, but the wiring diagrams I've seen, show bonding from cpc's to extraneous conductive parts, how do you connect a 4mm cable in a light fitting? I've also read on this forum, that the supplementary bonding should not go back to the MET, but I've seen tell tell signs of 4mm earth cables in CU? So how was it installed?
Hi,
Back in the days of the 15/16th the norm then was to run a 6mm to the bathroom from the MET/CU and bond everything in the bathroom , lighting, pipework etc as a radial circuit. Times have changed but I personally liked the idea; and yes it was sometimes a pain in the a** to make off some of the connections.
Regards.
Well connecting a 4mm to a lighting circuit is easy, assuming you don't use pull cords ;)
From what I've seen the norm was not to bother but failing that just connecting everything to everything else and to take it back to the MET was just good practise
Bathrooms required equipotential bonding.
Theory being to bond together every bit of pipework coming in.
IE if the bath taps, basin taps, radiator etc were bonded together then there is no possibility of a voltage appearing between any points and hurting somebody who at that time will be at their most vulnerable, naked, wet, condensation everywhere.
Heating pipes and domestic supplies are capable of bringing in a voltage. Boiler, pump, immerser etc can develop faults.
I dont remember having to include lighting.
Lighting rules were no pendant type fitting on which condensation could run down the flex into the lampholder. Batten lampholder with a Home Office Skirt or enclosed fitting only.
Taking it back to the met is a different thing, EARTHED equipotential bonding.
Boydy
Blimey home office skirt batternholder, I remember that, wonder where the name came from (wot was the IP rating!). I've read on here quite a few times that bringing earth cable from cu into the bathroom was big no no. Is that why all the diagrams show wired to cpc. I've seem quite a few with 4mm's back to CU though.
Back In The days before RCD's,everything was supplementary bonded, metal windows, doors, drainpipes, door hinges and handles even the dogs metal dog tag.
If it was metal and the was a chance it could become live it was classed as an extraneous conductive part and bonded. Lol
When it came to an airing cupboard, plumbers would say it the sparks job and sparks would say the plumber should have bonded all the pipes together. bonding had to be bonded. I even bonded my car when I parked it into the garage at night, in case it rose to a dangerous potential overnight. Lol.
Prays The Lord for RCD's Loling around the floor rolling my a## off
now that bit about the car is totally wrong. should have had it's own TT earthing, independent of the house. :driving:
It’s quite simple, if it don’t move and it’s metallic, slap a f***in* big earth on it.
No extraneous earth cobblers. Metallic, it’s earthed!
Window frames were a bit extreme. But between the various versions of the regulations who can’t point to brain farts on the part of the IEE/IET over the years.
Just keep in the back of your mind, Mr Cockburn was MIET.
Hang on, so am I!
That's one person so far, interested to know how your terminated the cable!
If you mean a normal light pendant then there is usually a fair a
sized earth terminal. 4mm will fit in it, as long as it is not deformed/mangled. Keep its cross section the way it was when it was made... A perfect circle. Then there is a slim chance you may also get the other cpc's in. If not join them together another way within the enclosure, as in a choccy block (oh no!!!!!).with a bigger hole.
not sure what you're getting at....?
I'm going to do a job, where there's no obvious sign of supplementary bonding, i.e. on bathroom rads, pipes etc. Nothing in the cu. So I started this thread just to know where else to check, before I test pipework continuity.
Taking a bond to the Bathrom lighting circuit was standard,not rare practice
I have seen literally hundreds of installations where the lighting has been done this way
Many of these had a rising cable near where the bathroom pull cord was located,if the terminal was not meaty enough,then a connector block was fitted
The supplementary bonding could also be found external to the Bathroom,in a nearby cupboard etc
Yes thanks seen bonding in nearby cupboard, just never seen it taken from a light, so I just wondered if that was ever practised and it seems it was.
Hot to cold to rad to light CPC was the norm when I was at sparky school.
Not done any domestic work since then mind you.
In my own bathroom, the pipework is all bonded together, together with the shower, towel rail and lighting CPCs. The 4mm goes up through the airing cupboard and into a downlight junction box.
Reply to Supplementary Bonding - How was it wired? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
In my bathroom there is supplementary bonding of the bath, bath pipework, and basin pipework before it goes into trunking and exits unconnected in...
I've wired some cable to a small 3x3 shed with 2 gpos, a 15a GPO, and a light. The shed is about 2m away from the house on a concrete slab. The...
Well....wiring in a 1750s thatched cottage attic, not wiring made from thatch 🤪 One we have been letting for over 20 years (as well as enjoying...
4K
Hi guys, has anyone got any experience of resistances through press fit plumbing fittings? Just been to a job I did last year which was a...
I have a baffling problem with a newly-installed PIR floodlight and I'd like advice from the forum as to whether it's defective (and should be...
