Discuss Table saw switch in the UK Electrical Forum area at ElectriciansForums.net
Andy would a selector switch work ?Looking to replace a table saw switch. The saw has a slow start motor, so the usual retrofit start stop switches won’t work.
Anyone ever replaced one/recommend a retrofit switch?
Just how many terminals are on that switch, it sounds like it is opening and closing the load of the motor not the wiring going to the coil which starts the motorNo pictures. Had the switch open, it has a coil
In it, when the start button pushes down into it. It has 3 cores and earth going into the motor. Switch is defiantly faulty as it’s seized and melted at the base.
Andy we are just trying to help you and your problem. Good luckOk megawatt, can’t remember how many terminals.
Andy good luck and hope you get it fixedThink I will open up the motor and check where these cores go to
Reply to Table saw switch in the UK Electrical Forum area at ElectriciansForums.net
