Discuss testing 2 radials in one mcb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
not different circuits. the OCPD is the start of 1 circuit, no matter how many cables it feeds.
it's 1 MCB with 2 legs going out. each leg to a socket. so basically 2 radial branches. whet would be of concern is if the MCB was a 32A feeding 2 2.5mm legs, not configured as a RFC.
i know. my question was whether 2 cables feeding 1 socket would be classed as a ring or a radial. i'd go with radial.
Reply to testing 2 radials in one mcb in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all EICR today on a ground floor flat .. 1 issue .. At the consumer unit there was a 1mm core with its yellow (sleeved brown) in a 20A radial...
Hello, I had an eicr done in 2021and it passed with four C3 items. They recommend next test date to be in 3 years instead of 5 on the certificate...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
All sockets wired radial, 2.5mm, lighting 1.5mm. Question 1. Is it ok to have two radials on one CB? No more than 4 outlets on each radial...
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
