Discuss Testing during a consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
TJC1
Evening all
When doing a consumer unit change, how much dept do you all go into? Do you treat it like an EICR with 20% ish and spot checking?
Normally we do end to end, r1 or r2 and IR test once the old board is off and Zs when the new board is on. We try and find end of the line on each circuit and also spot checking.
Didnt know if there is an offical reg/ruling of how much you should do
Evening all
Might not be a Reg, but there is a "Best Practice Guide" You might want to read it, before you take on any more CU swaps
Evening all
Personally I try not to get into Debt on any job I undertake
I think this is a good question.
Imagine doing L-N IR tests for every circuit. That might be ok for immersions, cookers, shower etc but for socket circuits and lighting circuits you could spend half the day hunting down something left plugged in.
I tend to just do L/N-E IR tests for the EIC with regards a CU change.
Maybe a good question HHD but for someone charging people for EICRs it's somewhat disturbing that they haven't read the Guidance provided by the IET or more importantly the "Electrical Safety Council" What say you???????
I always did the testing as if it was new. Never charged for an EICR beforehand, but that was included in the price.
e.g that wasn't an add on.
I insist on a full EICR being done in advance of a board change and include the cost within the overall price. If the customer doesn't like the price, then fine, get someone else to do it.
Got plenty of work have you? sorry couldn't help myself
I didn’t do EICR’s. But don’t think I would of got many jobs if I insisted on one before a replacement CU. Or are you saying you did some testing before taking the old one off the wall?
I do a full EICR before the board is removed from the wall.
Do you charge that separately, or is that inclusive of the price for a CU change?
I only ask, as some, for an EICR, appear to charge fixed price & in addition price per circuit?
As we're in open forum, lets say a silly price of £500 & £50 per circuit for the EICR, then £1000 for the CU change (normal 3 bed domestic property, dual RCD CU).
I just used just charge the £1000. However, I'd carry out some suitable testing, the day or so before.
Reply to Testing during a consumer unit change in the UK Electrical Forum area at ElectriciansForums.net
Hi Everyone, Last year arranged for my mother's and my consumer units to be changed by the same electrician who is NICEIC registered. Both jobs...
I just finished a garden room supply. The customer already had a CPN garage consumer unit that the last sparks left there, brand new in box, and...
Hi Guys, hopefully someone will know the answer. Testing an install on a (domestic) PME system I have a garage consumer unit supplied from one of...
I was just googling for skeleton boards after reading the last thread and various pictures of consumer units popped up, some wired terribly and...
