Discuss TN-C-S / Pyro / Outbuilding Upgrade in the Australia area at ElectriciansForums.net
SW1970
Hi, bit of a job with scope creep going on. "Oooo it's so good we've found a nice electrician we can get all these things done that we've wanted for years". Client wants new outside lights on garage but existing isolation and circuit protection supplying garage is falling apart so that needs sorting too. Circuit to garage is on buried 2 core pyro of unknown depth and routing. Existing old Wylex isolator and fuse in meter cupboard is rusting and existing old Wylex isolator and fuses for lights and sockets has no RCD (sockets are used for outdoor equip). So these items need replacing and upgrading. Primary concern is earthing, installation is TN-C-S. Earthing to MET is ok. Have a look at this sketch (red is new equipment replacing old, blue is existing and propose to retain):
First time I've worked with pyro. Not sure which rating as existing terminations aren't marked so assuming worst case from Lenny's sticky it's 8.2mm2 equivalent. Any thoughts or guidance on this one? Many thanks as usual!
Pyro is not suitable for burying direct and it is an extraneous conductive part. I'd start from scratch and abandon all the existing.
Edit - where I have said its an extraneous conductive part is incorrect and is nonsense.
Spades have been known to go throught SWA as well, Pyro is a good cable and still insisted on in some locations, problem is, like always, more and more so called electricians have never used it, or know how to pot and terminate it.
Too true. Would last longer though!
The pyro is not an extraneous conductive part,it is a conductive part as it is the supply cable to the garage and part of the electrical installation.
Whilst I agree that a direct buried pyro is not ideal,as it is already there,and if it tests out ok and is of adequate current carrying capacity I cant see the point in changing it.....use it.
So you inventing a new reg, buried metalwork is no longer an extraneous conductive part, lol.
Sw1970, apologies if Ive wandered with my lethal diamond tipped spade on your thread. I hope you can come to a satisfactory conclusion as to what to do!Wirepuller-would you want to see / confirm its depth over the run?
An extraneous conductive part cannot be part of the electrical installation....I am not inventing regs...you will find this information in the definition of an extraneous conductive part in the BRB/BGB if you bother to read it.......(lol)
Sw1970, apologies if Ive wandered with my lethal diamond tipped spade on your thread. I hope you can come to a satisfactory conclusion as to what to do!Wirepuller-would you want to see / confirm its depth over the run?[/QUOTE]
As long as there were no obvious issues...no I wouldnt. I would just do a cert to cover work within the garage,as the refurb of the garage install and a few additional points is the object of the excercise.
bet noone knows what heatshrink was---it came out about 25 years back but was discontinued it replaced the micc pots , had to use a special attachment on a blowlamp to terminate it
also there were pots that didnt screw on, they had a separate brass wedge instead-- and you had to use a converted set of molegrips to crimp the wedge into the pot
micc is very underrated imo this new stuff is impregnated with silicone so it doesn,t get moisture in the insu, not like the old days, no silicone then-- u had to work fast or the meggar reading would be low
if an old mineral had damp in it you used a blowlamp to drive it out after removing the pot
bloody sparks these days wouldn,t know **** from clay, if they were presented with an micc job
Reply to TN-C-S / Pyro / Outbuilding Upgrade in the Australia area at ElectriciansForums.net
Evening Chaps As can be seen in the attached photo , the incoming supply cable has a Earth soldered to the outer sheath of the cable suggesting...
Trying to understand why car chargers attract this earthing ballache. from what I learnt it's all about the rare times a Neutral / PEN conductor...
Afternoon all, Got a bit of a strange one (by my usual standards anyway). Job is a large barn conversion, done years ago, there's loads of work to...
I am about to install 4 sockets in 4 separate stone enclosures, housed within a large stone outbuilding. They have stone floors and are completely...
