Discuss Tumble Dryer Drum Earth Strip -- DIY strip OK to use in the Electrical Appliances Forum area at ElectriciansForums.net
The earth strip on our tumble dryer needs replacing as the drum spindle has worn through it. A replacement strip is around £10.
As the strip is a thin piece of copper, about 2in long and 1/4in wide, £10 seems way too much to shell out. I've made one from a copper pipe clip (cost 14p). Would it be safe to use this DIY strip?
Pic shows the £10 replacement strip.
That doesn’t look like copper to me, and I can’t imagine copper would do the job.
That strip will almost certainly be a brass alloy with a high degree of spring to it, copper work hardens far too quickly and will snap off in pretty short order.
davesparks -- yes, the worn out one is very springy and looking at it again it's definitely a brassy colour. I don't want to take any risks, so guess I'll be buying the part I need.
The bearing is worn -- it's 21 years old. The dryer had started to make a screeching noise, so I'm replacing the drum shaft, and hope that will fix the problem. The tip of the shaft comes into contact with the earth strip, and had worn a perfect hole through it. At first I thought the strip was meant to have a hole, and it's only by checking for spares that I've seen a new part has a depression for the shaft tip to sit in. After 21 years, the shaft has worn its way through the strip.
After 21 years I'd say you've had your monies worth out of it.
I'd be looking at buying a new machine.
...And on a note of -----attention to detail...i replaced the shaft and bearing on my old dryer,changing the bush,for a hi-temp,sealed roller bearing.
I part drilled the end of the shaft,and tapped in a 6mm ball bearing,to run on the strip.
That was six years back :)
I have some good friends,in the white goods job,and over the years,we have all benefited from the swapping of information. One thing we have deduced,is when it comes to dryers,the longest lasting ones,are always the cheapest,with the expensive models giving the most trouble.:)
Reply to Tumble Dryer Drum Earth Strip -- DIY strip OK to use in the Electrical Appliances Forum area at ElectriciansForums.net
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
78K
M
Hi all, very sorry to bother you with triv. I am in the process of sorting out some pretty shocking electics in a house that has been bodged at...
mbga9pgf
M
