Discuss Under cupboard lights in the Lighting Forum area at ElectriciansForums.net
i=p/u
What yous all using for under cupboard lights , and is quick fit
Depth can only be 30mm and length 300mm and don't want to be strip light if can help it,
Thx
Another one;
Ansell Axiom LED Strip Lighting & Accessories - https://www.electricalcounter.co.uk/products/Lighting/Indoor+Lighting/Ansell+Indoor+Lighting/Strip+Lights+%26+LED+Display/Axiom+LED+Strip+Lights
I know a lot use the LED, installed looks neat. But from experience, some of it comes unstuck, especially in existing kitchens. End up installing the extrusion, which increases the cost considerably. If the customer wants, LED strip, colour change etc, use the strip with ali extrusion. If not, keep to something simple IMO.
LED Strip should ALWAYS be installed in or on an extrusion for heat dissipation away from the diodes, it should never be stuck directly to a cupboard (or non-heat conducting materials).
Adhesion aside, it will drastically reduce the lifespan of the product.
The cheapest option, for LED Strip, is to simply use a 3mm thick flat bar aluminium. A 5m length comes in at about £4 from places like Richard Austin Alloys. Cut it to length, drill and countersink every 500mm, clean the face with degreaser and then use some kind of primer. This could be 3M Primer 94 (the best by costly option) or a Nonsense spray adhesive from Screwfix will suffice 95% of the time. Once tacky, apply the tape.
Reply to Under cupboard lights in the Lighting Forum area at ElectriciansForums.net
Hi, does anyone know where I can buy a replacement light fitting like the one in the picture? It takes a s15 bulb 284mm and the length can be no...
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
As the title says. But then I cut off a jst connection off one of the light strips and I can't get them to work together... the one strip is plug...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hi everyone We have some 10mm PCB RGBCCT strips (6 terminals/wires) being installed in the kitchen under the worktops However electrician is...
