Discuss Voltage regulator which regulates voltage coming our of a DC Generator in the DIY Electrical Advice area at ElectriciansForums.net
I need a strong voltage regulator that is used to regulate the voltages coming out of a continuous DC generator. Four poles of high current currents that connect with the thermometer to output a 24 volt voltage to the load. Control by magnetic coil files controlled by an automatic voltage regulator is input 24 volts and output to magnet files with an 8 amp amp Sorry used in the field of old armor
Reply to Voltage regulator which regulates voltage coming our of a DC Generator in the DIY Electrical Advice area at ElectriciansForums.net
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
Extremely low voltage on 120v line Hi, I’m not an electrician but my home has 20 amp breaker that has only one outdoor outlet on it with a GFCI...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
Hi every one. I have a NC relay with the below features which is written on the relay: Input voltage:12V dc Output switching voltage: 220V ac...
Hi, So I'm replacing a small old off grid with a new 7.5kw off grid, & being poor seek best value for my mppt, after long searches I find this...
