Discuss water heater switch in the DIY Electrical Advice area at ElectriciansForums.net
I
ian00uk
Hi
I have this switch in my kitchen which use to be for water heater. It now powers upto fcu for boiler.
Can I change this switch to a socket in kitchen?
If it's the FCU for the boiler, you can't really change it. If it's in addition to the FCU, you possibly can depending on the type of circuit.
I'd ask an electrician to pop in and have a quick look.
It's on the ring main in kitchen but the switch powers the fcu for boiler. So if you turn switch off in kitchen the boiler turns off completely
shouldn't be a problem then. brown to red and blue to bits,:93:
If the switch is part of the kitchen socket ring then it is probably possible to change it to a socket, so long as you do not affect the operation of the boiler, such as if the boiler FCU is inaccessible.
Reply to water heater switch in the DIY Electrical Advice area at ElectriciansForums.net
Wonder if anyone can help out, my experience in heating is minimal. So house I was working in had a circuit for the water heater, which went to a...
Hi, Because of the recent epidemics of so called experts with absolutely no proper qualification, nor knowledge, I'm forced to learn more on the...
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP! Every so often (twice in the last two days) when running the hot...
DIY'er question: I have a singe switched fused spur above my kitchen counter, providing power to an undercounter fridge socket beneath it. The...
Hi my name is Gintas I connected solar hybrid inverter to my house ring supply and it work very well everything except the gas boiler for on...
