Discuss Water heater wiring advise please in the UK Electrical Forum area at ElectriciansForums.net
Hi all can someone give me some advice on what kw heater I can use with this speck
Fuse board b32 rcd
Cable 2.5.....10 metres long just for water heater (nothing else conected)
Water heater will be in downstairs clockroom and use just for hand washing.
What size in kw can I use and how can I connect
Thanks in anticipation........Keith
Hi thanks for your reply I had a new consumer unit fitted and the electrician was informed that it was going to be used for a small water heater.
A standard 2.5mm2 Radial would be on a 20 Amp OCPD
and it all depends on the installation method of the 2.5mm. if method C, then it's good for 6kW max. if in insulation, 3kW max. but that's pushing it to the limit, so I'd be inclined to downsize those figures to 5kW and 2.5kW respectively. as Rob said, the 32A MCB is OK as it's a fixed load.having said that, a site visit is needed to confirm.
Hi telectrix thanks for your reply ......the cable runs under kitchen cabs up though a stud wall without insulation into a loft space above the insulation,so if I read your info correctly it will be ok with 3.5 to 4 kw ?
Best you get the circuit checked.
New circuits, like fuseboard changes fall under part P of the building regs
As i read it, the circuit had already been installed by a spark, but without a water heater on the end of it. OP wants to fit one and is asking for advice on what size he can get. even so, i's get a local sparks to check the circuit and advise accordingly.
Reply to Water heater wiring advise please in the UK Electrical Forum area at ElectriciansForums.net
I have taken delivery of an undersink water heater. It is fitted with an RCD on the electrical supply cable which terminates with a euro-plug. I...
I'm looking at a vending hot drinks machine 2.9kW that has a thermostatically controlled hot water tank permanently attached to a water supply...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Can anybody advise? I have a 3 rate old style electricy meter with 3 rates (day, night, and stored energy) Storage heaters are completely off at...
Hi All, I own a country Villa out in the Spain countryside. Was having problems with water pressure so local tradesmen advised to get a water...
