Electrical2Go - Online Electrical Supplier
Advertisement - Content continues below
Discuss What back box should I use in the Electrical Forum area at ElectriciansForums.net
telectrix
Mentor
if the holes line up use a conduit box or a round dry lining box.
telectrix
Mentor
what's it going to be mounted on? wall, ceiling, brick,dry line?
Charlie_
I made these yesterday for a similar situation..
4 diddy pendant fittings..
Glue bases to new plastered ceiling and then screw brackets up
Charlie_
Sorry posted that before I seen your last post..
I would just drill and screw the the fittings to the wall, leaving enough room behind for connections
Tony Reidy
  • #12
In this case I would simply chop a small hole into the brick to shove the connector block into and amount the light directly over the hole...
Looks like the only thing I can do but it's not good practice is it
telectrix
Mentor
it's how thousands of wall lights are fitted. the connections are accessible just by unscrewing the fitting.
Reply to What back box should I use in the Electrical Forum area at ElectriciansForums.net
SuperlecDirect - ElectriciansForums.net Electrical Suppliers
Top Bottom
