Discuss What do I need in the UK Electrical Forum area at ElectriciansForums.net
I used to do residential electrical work on the side but it has been decades.
Here is my question. I need to run a service from the power pole to a storage building that I want to run electricity to. It is about 100 yards, or so, and I need to know what size wire I need to run from the meter to the fuse panel in the storage shed.
I will be using the shed to work on different things and I will be using a 100 amp fuse panel. Thanks.
#1 AWG copper or 1/0 AWG aluminum. Whatever panel you use, make sure you have a main breaker for this! I'd suggest some anti-corrosion (nolox) on main connections, especially if you decide to use aluminum.
And don't forget to run a ground loop: 2 ground rods, 12' apart, #8 or #6 AWG, continuous to/from ground bar in panel. Be sure to BOND the neutral to the ground.
you need # 3 copper
Reply to What do I need in the UK Electrical Forum area at ElectriciansForums.net
Metal building with living quarters the panel is on the outside and about 20 feet away from new build that will be 2x6 what type of shielded wire...
I’m planning on putting in a small (10x10) detached shed for garden storage plus a freezer for meat storage, an in-wall AC unit (for temperature...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
