Discuss What resistance should a Solar iboost Clamp have? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
4Dave C
Can someone tell me what the resistance should be for a Solar iboost Clamp? My clamp is regestering zero ohms and I want to confirm this is the problem. The main unit is working fine and pairs with the sender. The sender flashes and the main unit will show error if I remove the batteries from the sender. The unit is not registering power and the kettle test is not working. The clamp is connected to the correct mains wire. I disconnected the wire from the sender and measured the connector with an ohm meter and as noted earlier, it read zero ohms. I am pretty sure this should have a resistance as I measured the clamp used for my energy monitor (Energenie) and that clamp shows around 35 ohms.
Reply to What resistance should a Solar iboost Clamp have? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi, I have a 6kw PV with a 6kw Growatt battery and invertor. I have a solar iboost going to the hotwater tank. Recently I had a Ohme Home Pro...
Hi all. Bit of a weird one. Have solar PV with a iboost +. All was working fine until meter was exchanged for a smart meter. The system is still...
4K
V.early days, just had installed solar. No battery, also supply of some parts difficult at the moment so no App or Online monitoring. I have a...
Hi all, In July I had a PodPoint Solo installed at my house. It was a secondhand unit from my father in law. I've just recently realised it's...
