Discuss What to do with chasings in the UK Electrical Forum area at ElectriciansForums.net
Hi guys,
I would be hugely appreciative for any input on this.
Basically my electrician did a full rewire and didnt use any capping or conduit, which as I understand is OK within the regs (as long as RCA protected which they are), but considered a bit unprofessional in the trade depending on who you talk to.
The electrician 'made Good 'in the chases for an extra 100 quid. I said about the wires poking out and he said it doesn't matter as the plasterer would be going over them. I think the plaster is usable, as such I dont need to have the walls replastered. So now I need to know what to do with these chases sonI can get the wires under the surface if the wall.
My instinct on the last 2 (dining room) is that I can chip away the existing plaster that he has used and push the wires back and go over it with a filler so that they sit properly in the chase. I'm a bit afraid of doing it though as I'm scared I may damage the wires. Also it looks like the wires have crossed over each other in the chase..is that supposed to happen/ok?
My biggest concern is the picture below where the wire is dropping from the ceiling (breakfast room) in the chases. No amount of plaster would set that right..it just looks like he hasn't used enough wire.
I am really at a loss as to what I can do. As far as I am aware as there are no regs broken I dont have the right to demand he comes back and fix it. But I dont know what I can and can't do.
If you guys could let me know how you would deal with this I would be hugely grateful. Any input at all...its honestly cooking my brain!!
Cheers!!
Have you paid for the work?
Have you received an electrical cert for the work?
Is this the same electrician that did the work in your last post.
Thanks for your response.
Yes, paid for the work and received certificates. And it is the same electrician from the last post. The work was done in January but due to lockdown and ill health I havent been able to look at doing anything until now.
That will all skim over ok. Will need plasterboard anglebeads to form new corners though. Use scrim tape to cover up any cracks or week points in old plaster. Will also need 50/50 mix of pva (twice), the architraves will also need to come off around any doors.
I plastered over something a lot worse a few weeks back for a mate. The electrician had run so many cables including the 25mm consumer unit tails, none of it was capped.
He was a qualified electrician and signed it all off but I thought the whole thing was absolutely awful.
Anybody else and I would of walked away but this was for a mate like I said.
Once plastered you would never know what was going on in the wall, Just try and make a note so you don't put a nail through a cable when hanging a picture etc.
I'm assuming all the electrical works has been signed off?
Pretty rough, tbh. I can only assume that the installer assumed he was being followed by the plasterer. As others have said, you're kind of stuck with it now but a decent tradesmen plasterer or decorater should be able to tackle it without too much hassle.
As above, it looks rough.
Are all cables in the correct zones? See below.
Is it OK in UK to plaster over pvc/pvc that does, nt have some form of containment?
Seems to be the case, but he must have been expecting quite a depth of plaster to cover that cable cutting across from ceiling to wall.
looks like he's ran the cables up then used hardwall to fix them in position. If he'd cut a bit deeper on the chases, laid the cables flat and clipped them in position, they wouldn't be sticking out like that.
A decent plasterer would have refused to do that job untill the cables were clipped in the chase flatter or deeper.
Looks like he's trying to hold the cables to the wall with plaster, probably because the chases aren't deep enough to have cable clips in.
Scraping the base coat away to give some depth for the finish would be the normal fix but I suspect you'll just expose more of the cable.
I doubt that plaster has bonded to the wall very well at all, it's probably being held in by the cables.
There doesn't have to be any regs broken, you've paid for a rewire and paid extra for plastering.
Both jobs are shoddy and incomplete.
All the plaster in the chase needs breaking out, it won't be too difficult, then the cables need fixing back allowing enough clearance for new base and finish plaster level with the old plasterwork
Can I take it no regs were broken? PVC cables are normally required to be "protected against harmful substances in concrete or plaster". Does BS7671 not have something similar to this reg?
I'm not aware of plaster or cement being harmful to modern PVC cables, even lime plaster has been shown to not have any effect on it. The use of capping or oval trunking is for mechanical protection form the plasterers trowel.
That is Interesting. Would you have any references for that.?Is there any comment/notes in the UK regs about that? . I have also never seen any damage to pvc from plaster or cement myself up until very recently. Towards the end of the boom years here there was a huge demand for concrete. Suppliers would drop it off early morning, heavily laced with a retarding agent to slow hardening. This was unfortunately acid based. Its now coming home to roost causing all sorts of problems for pvc cables that came in contact with it
In the 60's it was High Alumina Cement that caused the problems corroding reinforcement, the collapse of the swimming pool roof at "The Sir John Cass Foundation" was the beginning of it being banned in the UK.
Interesting. My curiosity is aroused because the UK and ROI regs are so similar in many ways that I just naturally assumed you would not be allowed to plaster over pvc directly. I have no issue with it as clearly in the UK you nowadays don't experience any problems doing it (though it I, m not sure I would adopt the practice). But I wondered what your or if your regs had something specific to say on the matter?
Reply to What to do with chasings in the UK Electrical Forum area at ElectriciansForums.net
Hi I have an electrician over and he took over from an incompetent builder. The builder already installed the wiring but the electrician told me...
Maybe I've just been lucky, but I very rarely have an issue with customers paying, the vast majority have paid straight away or within a few days...
Hello All. I'm quite new to this game and gaining experience, but going well in the main. My customer wants to feed a Hob ( on island in centre...
I removed my baseboard electrical heaters (1981 installed) due to finishing off the room. When I had a new AC ductwork installed they changed the...
Hi all, I’m currently doing an electrical installation & maintenance apprenticeship (EAL) and wanted to know what additional qualifications you...
