Discuss Whats the blue stuff? in the Australia area at ElectriciansForums.net
Danny1
Hi guys, just found this forum and have something i hope you can help me with? My elec oven stopped working yesterday, was gonna check the fuse first so unplugged it from the socket, however on doing so the top prong of the plug has blue suff over it??? have no idea what it is, possible damp? so i havnt done anything else with it.
any ideas what this is? and should i change the plug for a new one or would just changing the fuse to see be ok and safe ofc?
thanks for any help.
mmm, unfortunatly what i thought, the appliance has been in for years, doesnt feel damp around the socket etc, so would it be ok to just change the fuse or should i change the whole plug?
is is blue or green? I would say if it is green you may have this
[url]http://www.voltimum.co.uk/search/green+goo+in+cable.html
[/URL]
It is obviously some reaction to two dissimilar metals. If your able, isolated the socket at the fuse board, and remove it from the wall and see if there is anything a miss. If there is this green goo, it may then pay you to contact a local electrician and get him to have a look and possibly do you a PIR
If oyu find anything, then post your location on here, and one of the lads will I'm sure be glad to help you out.
Would that be a blue gooy substance or a greeny blue gooy substance?
Change both the plug and socket. If the Goo is in the back box wipe that out. Highly unlikely the insulation has been damaged.
its a greeny blue colour and its sort of like dusted onto the top prong, bottom 2 prongs are fine and clean.
It could be Copper Sulphate. Maybe the plaster around the socket was damp in the past and sulphates have leached out of the plaster and reacted with earth pin (only?).
Reply to Whats the blue stuff? in the Australia area at ElectriciansForums.net
Hi, I'm trying to rewire an old plug. I've rewired a few in my time, but all have been with the post-2006 wire colours. I have this old welder...
I have this motor from my egg rocker which the incubator was old and needed remaking, it’s a synchrononus 4watt motor that turns my plan is to...
im not sure where to post this.. and I need help [ I posted here because i guess Heating systems may need a hole this big , and this is the only...
Hello everyone! I'll start by saying an electrician is going to be called on this one, but I'm so curious as to what might be going on I just...
