Discuss When does labelling have priority over colour coding?? in the Commercial Electrical Advice area at ElectriciansForums.net
You do wonder if there is a reason, like a monumental c**k-up with some manufacturing and someone worked out it was cheaper to put on labels and re-print the manual?
Or maybe he who labelled just dropped one. Checks and tests?.....well it works OK!
Visual was a presumption.
The plot thickens.... having just come to actually wire it, the flex is just there as a courtesy, I have to terminate it internally as well. So..... do I correct it to U.K. convention and avoid a heap of labelling and possible confusion in the future or leave it Belgium??!
Sealing the deal..... the other two units don’t even have the internal flex installed! ?
To my mind, if they are not even going to connect the flex up then they should supply the units without it. Then the installer can decide what is suitable for the particular install.
It actually gets worse.....
Wiring Diagram inside the cover door:
Now the manual:
Sod this on a Friday, I’m off for a cold one!!
(NB... this will all get done to U.K. standards on Monday).
Reply to When does labelling have priority over colour coding?? in the Commercial Electrical Advice area at ElectriciansForums.net
Another thread asked about two circuits sharing a common multi-core cable and regulation 521.8.1 was mentioned. A friend of mine has inherited...
Hi all. I have a small question about inspection interval labels. We all know to fit one of these labels with the relevant date upon completion of...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
I just had the electric company at my house to check the power lines coming to my house. Nothing is wrong on their end. The problem is that every...
Hi I am carrying out an EICR. I have a garage mini sub DB supplied via 2 x 2.5mm T&E equivalent 5.0mm protected at main DB by a 32A mcb. I know...
