Discuss Which Panel Ground to Use? in the UK Electrical Forum area at ElectriciansForums.net
Binford
Hi folks, thanks for having this forum on the Web! I read up a bit on the following but still have a question about main to subpanel grounding:
I have the main panel mounted on a telephone pole just below the electric meter that feeds my home. I also have a small wood framed building (I call it a cabin). I installed an electrical panel in the cabin and fed 4 runs of THHN through SCH 40 conduit. My question is which ground cable do I need to use at the cabin subpanel; the earth ground wire from the pole mounted main box or from a grounding rod sunk in at the cabin? Also, do I need to unbound the ground bar in the subpanel box?
First off you need to bond the main panel on the pole. You said you pulled 4 wires to the cabin panel so you will have 2 hots a neutral, one neutral and an equipment ground. Yes you need to unbond the cabin panel. No ground rod is required at your sub panel
Reply to Which Panel Ground to Use? in the UK Electrical Forum area at ElectriciansForums.net
I am adding a 60 AMP subpanel for a detached garage/workshop with a 200 foot underground conduit run from the main panel to the sub panel...
I have a detached garage with a 60 AMP subpanel which has lost power. I traced the failure to the wire running under the walkway via conduit...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
Brian, DIY but 30-year commercial/industrial master HVAC tech. I have installed an emergency whole-house breaker switch next to my service...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
