Discuss Main panel and sub panel grounding. in the UK Electrical Forum area at ElectriciansForums.net
Brian, DIY but 30-year commercial/industrial master HVAC tech.
I have installed an emergency whole-house breaker switch next to my service meter. This will now be the main panel and I have subsequently tied my two grounds from grounding rods into the new panel.
The the original main panel is now a sub-panel. I have separated the neutral and ground. I have the four wires tied into it. Can I leave the original grounding wire attached to the box or can I only have the ground coming from the new main panel?
I am really just curious because it isn't hard to remove.
By code the first panel after the meter has to have 2 ground rods with # 6 bare wire going from the neutral bar to the first ground rod unbroken and then to the second rod. Any panel sub fed from your main panel has to have 4 wires pulled to it as you stated and keep all ground and neutrals separated as you stated also. You are also required by article 110-12 of the NEC to install ARCH flash stickers on both panels. Hope this helps and good job
Reply to Main panel and sub panel grounding. in the UK Electrical Forum area at ElectriciansForums.net
I have a main panel beside my meter on the house built in 1987. Then a 4 wire feed into a 200 amp panel on an inside wall of my basement. All of...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
At long last my wife is getting her new kitchen and the contractor will be running 10 or so new circuits from a new sub panel. The sub panel...
Hello, I live in Costa Rica, which adopted the US electrical code. On a regular basis, during thunderstorms, I have parks coming out of the...
I'm starting a new construction single-family residence, I know with the 2020 NEC they require an emergency disconnect on the exterior of the...
