Discuss WiFi operated socket in the UK Electrical Forum area at ElectriciansForums.net
Hello guys
Client wants to control a load attached to a 13a plug outside.
Initially I was thinking of large ip rated box containing a socket with a WiFi plug adaptor which will be installed outside.
If there an other ways?
Any of those Quinetic thingies fit the bill?
It needs to go outside, so a nice IP rating is needed.
Or do you mean get a standard outside socket and put the Quinetic controller inside?
You can get smart/wifi controlled relays although you'd possibly need to add a fuse if removing the plug from the load
i've used a couple of these for various applications---- outside lights,pond pums etc. no reason not to fit in back of IP65 socket
.https://www.ebay.co.uk/itm/Four-Way-ON-OFF-220V-240V-Light-Digital-Wireless-Wall-Switch-with-Remote-Control/252306287668?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Aren't these only suitable for lights, or am I reading it wrong?
could use to switch the socket using a relay.
Reply to WiFi operated socket in the UK Electrical Forum area at ElectriciansForums.net
I have a large gym in the garden and it gets ridiculously hot in the summer. I have utilised pretty much every inch of space and do not want to...
I have a bathroom fan with a moisture detector that turns it on and off. It also has a control circuit to turn it on/off when moisture is not...
Hello All, I am a homeowner (but not an electrician) and I am renovating a house that has an old CU containing MCBs and an MK LN5725 residual...
Hi, just helping someone out and apologies for the long winded post. Would like install a couple of weatherproof double sockets on the patio. 1...
