Discuss Wire nuts being sold in Lidl in the UK Electrical Forum area at ElectriciansForums.net
Oh I see, I didn’t even realise as you don’t really tend to come across them that much unless it’s an old installSome of the wholesalers also sell them. Definitely saw them in CEF.
I thought so as I couldn’t find anything saying they can’t be used. I always use wagos they’re much better than connector blocks anywayI believe they are ’allowed’ in the U.K.
but why would anyone bother with them
just grab some wagos
why do you think we call them Fire nuts.Wire nuts are used extensively here in Spain. Every time i have had a problem with a lighting circuit it has been caused by faulty connections in wire nuts. I don't bother calling in the "electricista" these days. I just find the bad connection and wago it instead. Always plenty of slack in the JBs to trim and remake the connections.
During my training, I remember distinctively being told that screwits were no longer permitted in the uk. Not sure if it is due to the fact that conductors need to be twisted together which is frowned upon?I wonder how many on here would pass comment on wirenuts without ever having used them for real? Good wirenuts can actually work rather well, but as mentioned they don't really have any advantages over other types of connectors that are in wider use over here. I don't like the uncertainty, when connecting more than two cables, about whether each of the conductors is equally well retained and connected.
Thankfully BS7671 isn't so prescriptive as to require or prohibit a particular kind of terminal. Regs differ; the NEC can be quite specific, stating for example how many of each size of conductor you can join with your wirenuts in each of thirty or so different sizes of junction box.
Reply to Wire nuts being sold in Lidl in the UK Electrical Forum area at ElectriciansForums.net
