Discuss wireless alarm systems? Good ones in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
gardtec 595 with wireless detectors ( keypad and bell are hard wired ). complete kit with 6 wi-fi detectors is £209+ vat. all you need is cable. available from risco.co.uk based in rochdale.
cheers boys. Saw the yale one on screw fix with 4 pirs and 2 door contacts for £160 but though it was a bit amateurish as the control panel just plugged in and the bell box wasn't hard wired good price though.
I'll check the gardtec one out, cheers
well thats the whole point of wireless,if your going to hard wire the bell and keypad you might as well hard wire the lot..
hi might be worth looking at the risco agility panels very reliable easy to install and totally wireless bar mains for control box. good signal strength
hi might be worth looking at the risco agility panels very reliable easy to and totally wireless bar mains for control box. good signal strength.
agree, but a lot more complex and expensive. risco tell me that you need a training course (1 day) on the agility.
I know what you mean with the yale totally wireless would probably be installed really quickly but thought the ones with the control panel to keypad and bell box were better, more professional. Noticed it also has a transformer plug on it for the control panel which is handy for someone whos not a spark and couldn't provide a fused spur for it.
the only thing i can say against the gardtec 595, is that it's a bit daunting initialising the setting up if you're not familiar with them. however, if you order one, ask for the full installer manual, and if you get stuck, their tech.help is a normal phone number (not a stupidly expensive call) and they are extremely helpful.
Reply to wireless alarm systems? Good ones in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Can someone please guide me on this? I have virtually no experience of home alarm systems. The client has an alarm which had been fitted to her...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
I currently have a home with 7 interconnected, hard-wired smoke detectors. I have a hard-wired heat alarm in the garage that I need to have...
We have a domestic fire alarm system in some leasehold properties. The existing BRK alarms are no longer available in the UK. These alarms/system...
