H
hightower
Dad has an old 1361 cartridge fuse CU, 16th edition so lights etc aren't RCD protected. It's Wylex, but I couldn't tell you the model.
Gonna be changing some lights in the bathroom from batten to downlights, 701.411.3.3 says I need RCD protection. I've told my Dad it's probably easier and better for him to get a new board (me doing it, it's only gonna cost him materials), but I wondered if it was possible to get an RCBO to retrofit to this board - anybody know?
Thanks,
Assuming it is an old Wylex Standard board then no.
Cheaper and better in the long run, to swap to a RCBO board.
How many circuits and I'm guessing you won't charge dad for your time?
No it's not that type, it's a typical 16th edition plastic CU with 1361 holders instead of MCBs, house was built around 2000 (my understanding is 1361 boards were very common on new builds in 2000 and 2001, must have been a dodgy deal gone on somewhere).
I would put a rcd s/fspur out side bathroom and alter the lights
Do the 1361 modules unscrew from the busbar.
Haven't had the cover off yet, but they look like this so I'm guessing they slot in to the rail like you would expect an MCB to.
Of course not haha, about 8 circuits. Think I'd just go split load if he did upgrade.
Why?
A 10 way populated AMD3 board with 8 RCBO's is about £120.00 - a far better solution now and in the future when a fault occurs.......
Reactions: Zdb
Why?
Is it? When I put RCBOs in mine it was closer (I think above) the £200 mark, and that was using a budget brand.
Just checked SBS prices (which I think are really reasonable) and that's £180 for 10-way, 8 RCBOs, VAT included.
how many led down light are you putting in!
for the cost of rcd s/fuse spur and alterations in the loft
best guess tops £75 including led lights & fittings and your labour for free!
Yeah just been looking through an old Wylex catalogue and it shows the 1361 modular units you have in your pic, NSB range. A new NHX rcbo should fit but as they are compatible with NSB but it might be tight in the board.
Reactions: hightower
I believe BG are the cheapest in terms of rcbos(around the £15 mark per CB) not sure on prices of an unpolulated board but it's £120 for the Circuit breakers alone. Id imagine the board would be £100?
Could you not fit an rcd board before the main board thus protecting all circuits on an rcd. Not ideal if there is a fault.
hightower post a pic of the board !
borrow a wylex RCBO from local wholesaler. try it for fit. if no fit, return to supplier.
I don't know why, but since you posted that something in my mind said "I've got a bloody Wylex RCBO in the box sitting in the back of my van". Not sure if it's 20A or 6A though, time to go check...
Reactions: Richard Burns
1361 Board, RCBO needed (25 chars.)
Electrician Talk
hightower,
hightower,
