Discuss Wiring for honeywell pipe thermostat L641B1004 in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
Evening all.
A friend has just rang from abroad asking how to wire up the above thermostat. He wants to use it to switch on/off a pump. I dont get into heating systems so am at a loss, but would like to send him some information if any of you guys can help.
This thermostat has 3 terminals (C, 1, 2) as seen in the first diagram on this link honeywell pipe thermostat wiring diagram - Google pretraga - https://www.google.co.uk/search?q=honeywell+pipe+thermostat+wiring+diagram&safe=active&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwijr6q_6MPYAhXIAcAKHWXHCfoQ_AUIEigC&biw=960&bih=600
1. Can it be used to switch the pump on/off?
2. What gets connected to C, 1 and 2 and where does this cable go?
Cheers all.
Evening all.
Cheers all.
do they want it to make on temp rise or break on temp rise? Is the pump controlled by a timer?
I dont know if the pump is controlled by a timer Lee. Could you give an example of the wiring if it was make on temp rise?
Cheers in advance:)
It’s a switch with an N/O and an N/C contact which operates at a set temperature.
If they can’t connect a simple switch then it’s time to call an electrician.
From the diagram it just looks the same as a 2 way switch, but where does the cable from this thermostat go?
Is it exactly the same as a switch? If so it has a PL and a SL, but that means the pump must have a seperate PL going to it or you have to use a JB?
So PL to C and SL to 1, so a 2 core cable. Then 2 core cable to where? The pump will just have a 3 core (l,n and earth) attached to it.
Cheers in advance:)
C and 2 make on temp rise, C and 1 break on temp rise. So if it's high limit you want then it's C and 2, if it's low limit you want its C and 1.
Without understanding the setup up its hard to advise. Perm live, timer feed or what ever you have to C and switch live to pump from 1 or 2 depending if you want the pump to kick in on temp rise above what's set or for it to run when below temp that it's set.
Yes it is a simple SPDT switch which is activated by temperature.
The cable from the thermostat goes to wherever you want/need it to go.
Depending on the power rating of the pump and the thermostat it could either control the pump directly (probably via a jb of some kind) or control a relay/contactor.
HHD, you could use a switched fused spur and have both pipe 'stat and pump flexes running back to it, live to the stat from the L load terminal and the return from stat to feed the pump in a separate connector within the spur box.
Reply to Wiring for honeywell pipe thermostat L641B1004 in the UK Electrical Forum area at ElectriciansForums.net
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT I have three wires in the old...
Hello everyone. Budding DIY enthusiast fascinated with how things work - and, to a lesser degree, fixing things that are not working. I suppose my...
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Im a DIY novice. I have changed central AC thermostat, light fixtures, switches etc. This has me stumped. I have a 240v single pole baseboard...
Hi, I'm replacing an old AT88A with the AT175F for my hydronic heating, which is connected to my 2-wire mercury t-stats and Honeywell V8043F zone...
