Discuss HELLO! How to know how much you uk socket can take? in the The Welcome Forum area at ElectriciansForums.net
Purely medicinal purposes ..wink winkFor horticultural purposes?
Power =Volts time Amps the max Amps would be 13 A governed by the 13 A fuse in the plug top times the voltage 240 Voltspretty self explanatory, just need to know how many watts I can pull from each plug as I'm going to be using a fair amount on extension leads.
Wasn't going to do the Math going to give the OP some satisfaction, seems he has done a runner so far13 a plug @ 240v = 3120w.
Yes, to turn that into the load that the BS1363 socket is tested to carry, the maximum load would be 4800watts.13 a plug @ 240v = 3120w.
Oh that's simpleNext will be a post on how to bypass the meter
Anyway, got a busy day today. Market in town, getting all Christmassy!
Completely agree! While most socket-outlets are rated 20A, the plug-top fuse will be limited to a maximum of 13A (approximately 3kW).Well....each extension lead is limited to a maximum of 13amps...
IIRC the test spec for BS1363 double sockets is that they should be able to handle a constant total load of 20amps.
Remember that according the the ESQCR, the voltage used in calculations is 230V rather than 240V. We use 230V because current is inversely-proportional to voltage when maintaining the same power (in Watts); as the voltage decreases, the current increases proportionally. In practical terms, this means that while maintaining the same power-consumption, if the voltage is grater than 230V (which is common) the current will decrease which results in lower temperatures in the conductors (which is safer).13 a plug @ 240v = 3120w.
No mate it was the EU that told us we had to be like the French, a big difference. We saved their backsides 70 odd years ago, and now they're telling us what to do, something wrong somewhere along the lines.yeah? i thought it was because we wanted to be like the french..
If you plug an extension lead into each socket on a double socket out let, the fuses in each extension lead will limit the amount of current that can be drawn.I think you misunderstand. The 20A test current is the sum of the currents through both sides of a double socket.
May not be so much in amperage terms, In my experience our average DIYer wrings his hands at the thought of plugging in a PC, printer, router and a 2TB disc into an extension lead, but will not even think about the implications of a washing machine + a tumble dryer in the same extension or socket.going to be using a fair amount
A total of 26 Amps from a double socket then?No you haven't. But that total of 2x2.99KW exceeds the design spec as laid out in BS1363.
That's why it is important to know what our (now long unresponsive) OP is planning to plug in to the extension leads.
His view of
I wait with ever increasingly bated breath - in the hope that we may learn of the application - but I fear that turkey, pudding, cheese and glasses of Portugal's finest may make me lose interest altogether.
as long as the socket's not MK, Lap, or chink export, should be OK for a half hour or so.A total of 26 Amps from a double socket then?
maybe he's tripped over his extension leads and broke his head.Come on people. The OP is not coming back. He's done his one post and most prob doesn't like the sensible replies and questions, so has thrown a wobbler and done a runner..
Oh no I can't take any more, well no more than a 1363 socket anywaymaybe he's tripped over his extension leads and broke his head.
Or died in the resulting house fire, that will get blamed on an electrical fault, as usual.
I'm surprised to see such misconceptions about fuses flying about in professional electrical circles!! Fuses are NOT overload devices...
I'm surprised to see such misconceptions about fuses flying about in professional electrical circles!! Fuses are NOT overload devices - they are Overcurrent devices - they provide short circuit protection ONLY. A BS1362 'plug top' cartridge fuse will not protect the equipment connected, nor provide overload protection ( well, not below about 1.6 times the fuse rating). The rating is the safe current the fuse will carry forever. Above that things start to get warm, then hot. A 13A fuse will carry 30A for 6 minutes or so, 50A for 0.1 to 20 secs, and 100A for 10 to 20 msecs. I believe it would take 1.6X rated, ie 20.8 A indefinitely, though things would get rather hot before too long! So, either fit some proper overload device, or a good smoke detector!
I'm fully aware of this, perhaps my post was misleading/vague in it's wording? Regardless, the appliance plug-top fuse is limited to 13A and it's highly unlikely that two 13A rated appliances will be used simultaneously from the same socket-outlet.I think you misunderstand. The 20A test current is the sum of the currents through both sides of a double socket.
What he said with bells on^^^^^^^^^^^^^^^^^^^^^^^^Anyone else in favour of following the rest of Europe in banning ring-final circuits to improve safety?
That's a big NO from me. We're leaving the EU, mainly due to the UK electorate being fed up with the tin-pot dictators telling us what to do (apart from grabbing millions of our hard-earned). long live the RFC, Red/Yellow/Blue, feet and inches, and English real ale.
Reply to HELLO! How to know how much you uk socket can take? in the The Welcome Forum area at ElectriciansForums.net
