Discuss New consumer unit and partial rewire in Didcot, Oxfordshire in the Electricians Jobs area at ElectriciansForums.net
Fat fingers and touchscreens are often culprits tooYes I’d already seen it but again different people have different views on different things and that must be his personal opinion.
Tbh the rating system has more positive than negative options. No one knows how other people are thinking at any particular time. My point to this is that we all have to respect others opinions without wanting in depth explanations.
Not against people having different opinions, it's just that the last 3 ratings (Old, Bad Spellings & Dumb) should be scrapped. Nothing good comes from them.
If I post something and someone thinks is Dumb then I'd prefer them to explain why. That way, if I'm being dumb, I will learn from it.... I learn nothing from someone just hitting the Dumb rating..
They're plumbers, the dumb is assumed.They aren't on the plumbers forum ............ so why on here @Sintra?
We have old for pete and Tel , we have bad spelling for Buzz and we have Dumb for...........
.......MurdochWe have old for pete and Tel , we have bad spelling for Buzz and we have Dumb for...........
To keep people like you happy as you do seem to use the negatives quite regularly.They aren't on the plumbers forum ............ so why on here @Sintra?
I can’t answer that question as I didn’t set up the forum software. If you feel the 3 ratings in question shouldn’t be there then don’t use them.
Do you realise how ridiculous that sounds, do you honestly expect Dan to remove them just because you don't like them. As Sintra has already pointed out , if you don't like them then don't use them.I've given you a dumb because these can be included or excluded - Dan could do this ................
I'm using the phone mate so can't see post numbers.I disagree with you there mate.
If Old, Bad Spelling and Dumb could be removed then it would be a good thing.
See my post #55 for why.
Tbh I’ve looked through at lot of members and what ratings they’ve given and those 3 are seldom used. The one person that sticks out that uses these 3 the most plus the disagree rating is our friend @MurdochI disagree with you there mate.
I think we are ever so slightly off-topic here.
Give me a dumb/dislike/stupid/whatever...
I ignore 'em all, except the Bad Spelling ones! GRRR!¬
In fairness to @Murdoch, there are a few low content members out there, that give 'dumbs' out, and very little else. I recall one guy give me a dumb for a very innocuous comment I made, which I challenged and he made no reply. Not surprising when he only posted about four times in 5 years!
@Murdoch big wow some guy has used the dumb button twice and I should be taking action against him. Well do you know what that isn’t going to happen. The rating is there to be used and it’s staying there so either use it or don’t it’s entirety up to you. Either way stop moaning on about others using it.
This all seems a little petty. I'd say there is a fair chance that a forum member that doesn't post a lot and doesn't give many ratings they have probably done it by accident more than anything, it's very easy on a mobile device to do that. Or they maybe meant it. Either way action against a forum member for using the rating system is a new one on me. Should they be getting bans for that then?
Well according to @Murdoch the guy that dared to rate one of his posts as dumb should be deleted from the forum. There will be no action taken against anyone for giving out a rating. Give me a dumb for this and see if I careThis all seems a little petty. I'd say there is a fair chance that a forum member that doesn't post a lot and doesn't give many ratings they have probably done it by accident more than anything, it's very easy on a mobile device to do that. Or they maybe meant it. Either way action against a forum member for using the rating system is a new one on me. Should they be getting bans for that then?
And what would you do if they took the optimistic button away?
Sorry Sintra, I really tried not to!Well according to @Murdoch the guy that dared to rate one of his posts as dumb should be deleted from the forum. There will be no action taken against anyone for giving out a rating. Give me a dumb for this and see if I care
Wher’s my ban hammerSorry Sintra, I really tried not to!
Sorry, couldn't resist it
I'll remove it in a bit.
I found it @SintraWher’s my ban hammer
Leave it... I really don't mind
Reply to New consumer unit and partial rewire in Didcot, Oxfordshire in the Electricians Jobs area at ElectriciansForums.net
