Hi Hayley, are the smoke alarms being interlinked with cable or via radio link? If it’s the latter then they are a lot more expensive.
Hi - probably want some payment, but you can discuss this. My standard terms are 1 year on lamps and dimmers. Longer warranty period is entirely possible but would likely incur an additional charge.Yup, I tried to price products with a warranty but I sort of assumed that if anything failed (say 2 years later) the electrician would still want paying again?
why 7 smokes?.......but if needed and 1 heat will come to about £250 alone for quality ones
Yup, it's £233 for the ones that the electrician recommended (AICO EI161E) and it's £264 for the multi sensor ones which I prefer (from fire angel)
My advice to you
Accept the sparkies quote or get more sparkies to quote
Messing around to try and save a few pennies will just leave you in dispute or with an unfinished job on your hands
When you take your car to the garage you leave them to it
PS : Aico produce the best alarms
I think that's part of the problem, when I take my car to the garage they let me go in the pit and have a look at what needs doing, they give me a price for a part and sometimes I get my own part if it's much cheaper to do so. I've used the same garage for 14 years.
And here lies your problem.
You've obviously got a long term relationship with the garage and they're happy to accommodate you. Whereas, you're expecting the equivalent with a brand new (to you!) electrician. It's not going to happen ... really!![]()
If going for click scolmore, have a look at the denmans range. it is made using exactly the same moulds for the faceplates as click scolmore. also cheaper.Hi Hayley
As you are going with Scolmore sockets, why not go for their downlights as well? I'd highly recommend their Inceptor Nano range, this will save you some money over the Aurora.
Hope this helps.
my friendly garage would also allow me to get under and see what needs doing, but i never bother.it's a Toyota Hiace. nothing ever needs fixing. (invincible, see Top Gear).
I am worried about messing him around hence me asking if it's feasible all the small ratings come to around £400, but £400 is a lot of money I think, not pennies?
