M
MicahfromMN
In my bathroom, ive got 2 switches that control the 5 bulb fixture over the sink. I replaced one with a 3-way switch dimmer, but not the other. When the dimmer is at the lowest setting, everything is fine, but when I raise the brightness, its flickers and buzzes. Where did I go wrong?
(pictured: new switch on left, old on right).
if the lights are LED it could be that the dimmer is not compatible with LEDs.
Reactions: Maji236
Thanks for the reply! The dimmer description says LED compatible. The bulbs are:
"BR30 LED Bulb 11W=65W, 3000K Warm White, 850 LM, E26 Base, Dimmable, Indoor Flood"​
what's the min. and max. wattage of the dimmer?
that's the max. does it show min?
Are these light fittings with LED drivers? If so, do the drivers also support dimming?
Why is my new 3 way dimmer switch causing my bulbs to flicker at high brightness?
MicahfromMN,
MicahfromMN,
