Sure the wire you would need to light it would be black to black white to white and your green ground. If that doesn’t work, at the dimmer use the red to the black in the cable
Reply to DIY'er: Will an L.E.D. dimmer switch work with an l.e.d. track light in the UK Electrical Forum area at ElectriciansForums.net
