Can't see Conlok lasting long floating above the gate. Threaded for me every time.
Possibly but as I say I don’t have a Bender or vice to hold the conduit. Plus I would have to buy a tap and die set and grease etc. I don’t use it in work so it’s a lot to outlay.
Paying someone to do the conduit would probably work out less expensive than doing the job twice.
Probably I but would like to attempt the job myself or how will I learn. I will cost about £80 for the conlok including delivery.
Do the job as you see fit.
With con lok, there's not much you're going to learn. Literally cut to length, de-burr and tighten hex head grub screw.
Reactions: DPG and Jim_e_Jib
I've bent conduit before without a machine using 2 strips of 1 inch ply screwed together with a 20mm hole in one end. Find a 90degree corner to hold the conduit, slip the conduit through the hole in the wood and use it as a lever to slowly form the bend as it starts to form inch the wood along to keep forming it into a nice radius.
An old spark taught me this method nearly 20 years ago when we were on a job and needed to bend some conduit but had no bending machine with us.
I used this method a couple of weeks ago for a 1off bend in some galv for a church light but had to use 3x2' timber as that was all that was lay about.
Sure there is nobody in your area willing to let you try their bender for an hour to practice?
Reactions: Jim_e_Jib
Conlock is IP30 so in a few months it will be full of water.
Nothing some ct1 and some drain holes won’t sort out the lad is triying to have a go I’ve personally used conlok on numerous occasions granted threaded would be better but without the equipment it would be the best solution
What about catenary wire and Hi-Tuff cable? You'll need metal cable ties for catenary wire as plastic ones often perish after a long time in the sun
I will buy some CT1. That looks excellent. I’m looking to paint it white. Would hammerite be okay?
Any advice on a tap and die set and any grease or sprays that I would need for the conduit. I’m planning on painting it. A mate is going to lend me his vice.
will your mate who is lending you the vice not lend you a die as well?
Reactions: pc1966
He’s just dropping it off the help me out. He’s got one, I wouldn’t mind buying my own. Then I have one for future use.
Just about any electrical wholesaler will have a stock & die set for 20mm & 25mm. They'll also sell a tin of cutting compound.
If you want something a bit cheaper, then ebay or Amazon should deliver.
Niglon stock & die sets seem to be the cheap option from wholesalers. While they aren't the best available, they're more than good enough for regular use.
Reactions: pc1966 and SparkySy
I would look on Amazon or eBay if you want a cheap low use one. Or your local wholesalers should stock them!
Edit @nicebutdim beat me to it!
I've been using an f4p one from cef for a few years. Cheap and cheerful and does the job fine. Think it was about 30 quid at the time
I still need to order the galvanised conduit and boxes. I was thinking about possibly getting someone to do it. I don’t mind having a go myself as we don’t use it in our line of work. Fire and Security. My mate also let me down with his Conduit Bender.
I’m also planning to paint it White, is there anything I will need other than some Hammerite Paint? Does it need to be rubbed down etx?
Would be so much tidier burying it, but I understand wanting to expand your practical experience.
Hammerite can be painted onto anything really, but if you’re painting boxes and lids, it will be difficult to remove the lids in future.
Not sure I could bury it tbh.
RDB85
Trainee
Liverpool
Trainee Electrician
Adaptable box with front entry.
RDB85,
RDB85,
