Discuss DIY - help! - RCBO consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Hello,
Which amendment of the 18th BS7671 required RCDs for protecting lighting circuits (domestic)? I was told it’s amendment 2. Is that correct? Or is it amendment 1?
It was definitely in 18th amendment 1.
Why?
An electrician installed a new consumer board in April 2022. They are saying that they didn’t need to protect lighting circuits with RCD’s or RCBO’s. As 19th edition only became current in 27th September 2027 (when 18th was withdrawn).
Wrong....get them off your job Now.....i suppose they were the cheapest price
There isn't a 19th edition. The 2nd amendment of the 18th edition was released on 28th March 2022.
I can't understand why anyone would fit a split load board in April 2022 when they could be bringing the installation up to date with surge protection and RCD protection for every circuit.
I think I know the answer, but did they give you an Electrical Installation Certificate?
Thanks, they are off the job. I didn’t mean the 19th edition. Assume that 18th amendment 2 is the latest?
Thanks Tim, I didn’t receive an electrical certificate. I’m really lost as to what to do and if they are at fault for not putting in a consumer board with RCDs for lighting. Thanks so much. Really stressed.
They are saying that they didn’t need too because the amendment 2 of 18th didn’t come into force until 27th September 2022. So they worked to amendment 1 of 18th version. So didn’t need RCDs lighting.
I assume the person you used isn't in a competent person scheme like NICEIC or NAPIT? By rights they should be if they are changing domestic consumer units as the work should be notified to building control. You should also have a certificate proving they tested it all and it's safe.
The original 18th edition (from Jan 2019) required domestic circuits supplying luminaires to have RCD protection.
It's reg 411.3.4 and it's in the blue book. So this argument doesn't hold water at all.
Here's a web page that was released when the 18th edition first came out that mentions the change.
The problem is that I'm not sure I'd want them to fix the issue anyway from what you've said.
It might be that RCBO's can be fitted for the lighting to avoid changing the whole board. But sometimes this isn't possible or cost effective.
I think you need to get a decent sparks around to have a look at it and give you some advice.
Thanks Tim, so helpful. He’s an electrician but semi-retired so fear he’s not up to speed on regs. He doesn’t belong to any organisations. Should he have notified Building Control? We have no completion certificate or record of testing (online or paper). The consumer board is also missing any labels so it’s hard to identify what is what. Assume that labelling of the board is a requirement for issuing any completion certificate or compliance with building regs / control approval? Thanks again Tim, so kind.
Jesus what a mess. You need to get a competent electrician involved, completely reinstall/replace and get the correct Certification.
Thanks, but from a fundamental legal position, would it have been possible to provide a final completion certificate and ‘handover’ with this? Would it be builds control notifiable (if not registered with any orgs)? He’s saying that I’ve lost the paperwork - but I was never given it and this is what I’ve been left with!
From you other thread has this individual rewired your house.
Yes, I’m trying to address each of these issues to him as separate items. There are more! But I’ve kept it to those that are harder for me to understand whether it’s compliant and so I can take a more legal position, as well as the obvious poor worksmanship.
Needs ripping out and a new board with SPD and RCBO's......and by the look of that you need your house testing...and HE needs his head testing
He obviously worked very hard to get that amount of bare CPC in the trunking under the CU.
I wonder what's on the other end of the two bare phase cables above the RCD? love the choc blocks.
Reply to DIY - help! - RCBO consumer unit in the UK Electrical Forum area at ElectriciansForums.net
Good morning guys Was looking for advice with regards to installing an outdoor consumer unit. Customer is looking for power to be installed from...
hello all...whats the typical cost for a new consumer unit fitted and the old wired fuse box removed im in a semi detached house in...
NICEIC Certification Scheme SPD on old consumer unit?
Under amendment 2 of the BS7671, there is now a requirement to fit an SPD as standard. I am due to install a new outdoor socket circuit on an...
Help please! I need a Tesla Gen 2 EV charger fitted in my garage which is 22m from the consumer unit. My electrician is proposing to route a 6mm...
Ok, most new Consumer unit seem to come with a 63A RCCB and two MCBs. Most house consumer units now will also have RCD of some type be it a dual...
