- Dec 23, 2023
- 40
- 2
- 83
- United Kingdom
- Manufacturer / Distributor / Supplier / Inventor - etc
- Business Name
- Mandalblit Services
There's a pic of inside the box there's black all up the rhs and inside it's black and scorchedHow do you know your system is perfectly balanced? Why is that board fed in tails? Generally heavily loaded single phase boards would indicate the system is unbalanced in my experience. I can’t really see why the spark had the tails out for testing either, just doesn’t really make sense.
Edit- no answer to my previous question either, did the cover actually blow off? How did that happen with threaded screws on the cover, did they break? Do you have a picture?
