May 17, 2025
San Diego, CA
United States of America
They do not flicker when it’s at max or min setting, but almost everything in between, it does.
New recessed lights. 4-pack from Home Depot.
Potential problems:
Some 12-2 old wiring, reused. (Best parts taken)
New 14-2 wiring used to connect the lights themselves to the box. 12-2 used to connect box to source.
Some circuit breakers throughout the house are double tapped at the main breaker. There have been flickering lights before. Not sure if this line is a 15 or 20 amp. Each light is LED at is less than
Sounds like the dimmer is not entirely compatible with the light fittings.
Is the dimmer a 'trailing edge' type, and known to be suitable for this brand of LED/lamp?
I’m not sure. They’re both from Home Depot.
Levotron is the brand of dimmer, and the recessed lighting is Commercial Electric.
Removing the lights now is difficult because they’re all push connectors. But I also ----ed out the box of the dimmer 🤦🏻‍♂️
I would say the first thing is to be certain that the light fittings are dimmable, which would have been shown on the box or in the product literature. Worth checking at Home Depot if there's any doubt, though it's probable that they are.
Otherwise it's likely to be the dimmer. You might find the model number of the dimmer you've used on the back of it, or on a label. Dimmer Types and Where They Should Be Used > How to > Leviton Blog - https://blog.leviton.com/dimmer-types-and-where-they-should-be-used
You could try changing the dimmer for a different model or brand of the 'trailing edge' type.
San Diego, CA
DIY Newly installed LED Recessed Lighting with Dimmer. Lights flicker when dimming.
USA Electrical Forum
BioMedEngi,
Avo Mk8,
USA Electrical Advice
Welcome to the USA Electrical Forum at ElectriciansForums.net. The friendliest electrical forum online. General electrical questions and answers can be found in the electrical forum.
This is the main UK Electrical Forum at ElectriciansForums.net. Electrician Laws and Regulations related to Electrics and Electricals within the United Kingdom. Electrician talk, questions and answers can be found in our UK electrical forum.
