M
MattyKHZ
When I started looking I was all set up to go with a company who was offering 250W Sanyo x 16 and 4000TL for £12,000. 10 year insurance backed warranty and 25 year on inverter. Fixings were K2.
The issue I had was they were pushing for an install with scaffolding going up on the day I came out of hospital from an operation and a very quick install. Tech survey was to be done on the day which I felt was odd as I felt if something wasn't on the van install would take place with whatever they had available.
A local Sanyo Premium installer quoted around the same time and told me about the K2 fixings for 35mm rafters, 3 man team with roofer, electrician etc. And the £500 premium seemed worth it. I felt I needed a new CU and wanted the Wylex PV CU with built in meter. The CU is in a cloakroom and felt that I did not want loads of boxes and stuff. I also decided on the Solar Edge Inverter and 12 year warranty. Provided all details etc and was told they would look into it.
Get told they are still trying (yet others are getting them from CAS) and that they had a 4000 TL reserved just in case. Then it was can't get and Sunnyboy it is. Invoice is for same price as Solar Edge system which I query as that had a premium. Then told extra is for CU yet I told them at start I wanted this so would have thought it wa sin Solar Edge quote. So query why CU cost works out to be same as Solar Edge system difference and this then gets reduced.
Today install takes place and not K2 fixings (was told they were ordered and secure) and some are adjustable some aren't and they will get them in the 35mm rafters at some kind of screw angle. When I asked about CU they will not use Wylex and instead will be Crabtree with seperate meter.
I was sold on their knowledge. To me it makes sense that german houses are different to UK ones so fixings like the K2 for 35mm rafters was a selling point. Solar Edge and its benefits/warranty were also a benefit as I feel was the Wylex CU.
It seems I have to be happy I am getting a Sanyo panel install and 4000TL. They even just quoted Sunnyboy on Invoice where as I felt if teh panels are quoted by make and model so should teh inverter as just as important.
And also it seems tiles have to be slight raised where cable and bracket are at the bottom. I have flat interlocking tiles and it seems these are not the usual (2007 build house). I thought they were supposed to be ground own slightly so did not sit proud????
