Discuss capping in the UK Electrical Forum area at ElectriciansForums.net
At the risk of being facetious, I'd say don't earth your capping, then get your rewires done even quicker. You do take a while. Daz
I was taught to always earth capping..old company still does it. Safe zones yeah but what if you install and a sharp edge of caping has sliced into a cable by accident ? you have just installed a large piece of metal in the wall that is now live...I earth it then I know I don't have that problem as any contact to live will also be to earth and trip.
I think it was councils who insisted on this even when not required..but Ive always just thought it was good practise too ! Id rather do that than potentially make a wall live, not know till someone soaks it with paint and gets plated.
i use plastic oval tube. hate capping. either the nails won't go in or they fall out as soon as you let go.
Don't use the nails they are useless, get a small decent battery gun with a decent magnetic screw bit that holds the screws steady. Screw straight onto the capping and the screw will pierce through, straight into a raw plug. Careful not to screw through cables...
- - - Updated - - -
Pint of stella please then barman
- - - Updated - - -
if i'm going to the trouble of drilling and plugging, then it's tube all the way. 1 hole per clip. and it's rewireable as well.
it's about time this thread got silly, anyway. it should have been trashed ages ago. time for beer.
your wish is my command.
this whole thread is just one jolly funny reminder why i use this site less and less.
good work fellow forum contributers on making yourselves look dumb ;-D
were you singled out in any way ?
no , so stop being so f****** uptight.
folk might think youre actually that ---- tank driver you proudly display.
Whoa! Calm down dear, no need for such a wobbly now is there?! I'll put those toys back in your pram now shall I?
I never said you singled me out, you just referred to contributing members of this thread being dumb, me being one of them. I wanted clarification on what I said that was so dumb, that's all?! Uptight? I don't really think so, just inquisitive as to why you would say such a thing.
One more thing, there's a line you simply don't cross. When you start making insinuations with words like '----' you're getting very close pal. Wind it in!
never seen u earthing ur capping on that youtube vid
Lets all take a deep breath and....... relax :)
Now.. Biff, say you're sorry and shake hands, you'll only regret it in the morning when you're sober!
Perhaps if you used the correct size capping for the number of cables installed and took your time instead if being a rough a*/'e then there should not be any concern about nicking a cable.
Also two lengths of capping is not a substitute for metallic earthed conduit. If it was deemed acceptable it would state in the regs earthed metallic conduit or similar but it doesn't.
yep. reg. says "enclosed in earthed concuit or trunking". capping does not constitute being enclosed.
yes, but then cables > 50mm deep would be at risk and they don't require any protection. you get builders and wood butchers around, anything can happen, but how far do you go?
Yeah sorry I was thinking about zones.
'A zone formed on one side of a partition wall of 100mm or less thickness extends to the reverse side only if the location of the accessory can be determined from the reverse side'
Think about it for a minute now would ya. What purpose does an earthed metallic sheath serve in a cable? Why would an earthed metallic length of capping be any different to this? We all know it isn't mentioned in the regs, but we're talking theoretically here right.
it would serve the purpose, agreed. a nail penetrating the capping and the L conductor would operate the OCPD.
So would it be fair to say that if it isn't listed as a method of providing penetration protection the same as an earthed metallic sheath, but, it is as safe as, then it could be listed as a departure from BS7671?
Because capping does not fully enclose the cable nor is it in direct contact with the cpc
fair in my book. as you say, it's no less safe than if it was done as per BS7671.
You are relying on an the capping being suitably earthed and without this connection being accessible for verification I would not deem it as acceptable. I could probably ask someone to give me a number of reasonably qualified reasons why earthing a piece of capping does not constitute as suitable protection but i have others things to do.
Unless the wall is so thin that the distance between the cable and the other side of the wall is less than 50mm then the cable doesn't need to be enclosed. Also, if the capping is earthed then of course it is in direct contact with the cpc.
No it is not in direct physical contact with the cpc of a cable. It is connected by a flying lead. I'm out.
Look feel free to do it your way but its not a suiable method as per BS7671 whether you feel it works in theory or not.
If i was inspecting the work on one of my jobs I would get you to do it as per BS 7671 regardless of whether you think its acceptable in theory or not.
Tell you what, how about raising it when it comes round to your scheme assessment. See what they say then.
Sorry, I misunderstood what you meant by direct contact, with the addition of the word 'physical' it now makes sense to me. Still, if the connection made was MF such as a rivveted or soldered connection then I can't see a problem, there's no need for a MF connection to be accessible for verification.
Good point, what if 2 or 3 different circuiits are behind one section of capping? Only one circuit providing the CPC to the capping. Then that circuit gets disconnected from the DB at a later date?
a valid point. go to the top of the class.
I think you need to have a read up on exactly what a departure from BS7671 is mate.
How you choose to work on your jobs is not really relevant to the discussion as this is entirely personal preference.
I am not necessarily saying that I would do it this way, but if I found work to be done this way ie. A cable has been protected within a wall throughout its whole length by metallic capping earthed by way of a maintenance free connection, the distance between the cable and the other side of the wall is greater than 50mm and the metallic capping is suitably sized in accordance with the requirements of section 543, then I would be more than comfortable to list it in the departures section of the certificate.
I'd be happy to, except when my renewal date comes in March I won't be renewing so won't have a chance :)
The same could be said of metallic conduit or trunking. You would have to ensure if this was the case that the capping was earthed to a common point.
Reply to capping in the UK Electrical Forum area at ElectriciansForums.net
Hi all, I am at odds on whether RCD protection is required on an SWA of 14 metres, clipped direct under flooring direct from CU to an exterior...
Hi All Recently bought a wandering lead and was practicing with it on a few of my relative houses checking if metal sockets / fittings /...
Hi all I have been pulled up by Napit, not by my regular inspector. Used rcbo's on a rewire (usually do). Filled out cert to reflect this, with...
Good day. First time poster. We recently had an electrician perform the EICR, as this is a newly purchased property I thought'd I would have the...
Essentially I have a "normal" socket in a ring mains, i.e. one 2.5mm T&E going in and one 2.5mm T&E going out. I am looking to simply add two more...
