Discuss Would you put a wall switch in a bathroom in the UK Electrical Forum area at ElectriciansForums.net
Yes , greater than 600mm is outside the zone so you can use light switches in that area as long as all circuits are protected by an RCD ,
You picking and choosing regs here and forgetting others... You switch is required to be suitable for the environment its placed in and as the bathroom is classed as having a high humidity and steam environment then a standard switch is not suitable as they do not provide good IP rating - the steam will condense on the cold plastic .... have you not seen this happen to the mirror?
This ^^^^ - Wet hands on an already steamed up switch - don't sound right, does it?? - regardless of where the zones begin/end
this is it...This ^^^^ - Wet hands on an already steamed up switch - don't sound right, does it?? - regardless of where the zones begin/end
Funny, but it's never been a problem in the vast majority of other countries, like the States Canada, most if not all of Europe, and just about everywhere else i ever worked or visited. More like the inherited UK's draconian rules that have always beligered UK bathroom installations.....
DC dark?....Maybe so but the nature of the switch means you usually don't get killed just a tickle or slam as you can't spasm clamp your hands on it till you fry, I have a plastic toothbrush holder and when I shower its full of condensation so why not a switch ...its to cover the small chance of a shock not the big picture of it rarely happens... we all know you can walk out of a bathroom with dripping wet hands when your body is at a lowered resistance and switch another switch on but in the scope of things its dry and not been ingressed with moisture while you shower.
Yes on the wider scope of things maybe draconian and extreme but the UK holds one of the lowest fatality by electric shock 'when the regs have been followed' than most other countries using the same voltage ... opinions always change when you know someone who has been killed by such situations ... 1 life is too many when it can be avoided quite easily by a simple regulation that doesn't add really any costs to a install.. Think your mind is been influenced by your location and your now slightly de-sensitised to our stricter regulations ..... I know you know your stuff ENG and hold you in respect but all i was doing was expressing a regulation.
DC dark?....
OK..thanks for clearing that up Dark.And AC .... its a myth its just DC that clamps your muscles AC works just as good but DC tends to do more damage to the body if your survive... the frequency is 50hz - your muscles can't relax and let go that quickly so still give lock out!
yep...thats probably what i should have said...Depends where you hear this but voltage and current are key ... in america AC is far less dangerous due to the lower voltage but over here our voltage makes it nearly as lethal, its quite possible to let go on 50hz but depends on the muscles under influence .. they will be pulsing 100times a second but DC holds no bars and even lower voltages can give permanent muscle lock so yes your correct DC is by far more dangerous but dont be complacent AC kills alot of people in this country because they can't let go ... hence the lengthy thread on the young lass that got killed holding the ladder to the loft.
this is it...
its a common misconception that you actually have to be in contact with exposed live parts to get a shock...
not so..
voltages can `track` across wet/damp surfaces...
i know that DC is more dicy to be dealing with..
no doubt Tony will drop in on this at some point....
I’ve worked on all sorts of DC systems. Some I was happy working on live, others I wasn’t.
We had DC control systems where I’d be quite happily be twisting cores together with my bare fingers that was 100V+ and yet I’ve had a belt off 24V-.
There is WAY too much reliance on RCDs in other parts of the world. I guess people don;t question getting a shock of ONLY 120v in the bathroom. "Hey man! That's Life!" Lol
In one of those fits of pure genius plumbers have we had a Jackson tea urn just below an old EE type SS DP 240V board. It used to fascinate me watching the magic electrickery stuff bouncing around inside it. I wasn't going to touch it!
The DC power systems 220V, 440V, 660V were supposed to be earth free (note, supposed to be). They all had high resistance earth fault monitoring, no one trusted it.
If the monitoring indicated a fault you’ve never seen an electricians workshop empty so fast.
I was taught that after testing for dead you tapped the busbars with the back of your fingers. The theory being you couldn’t grip the busbar, never got a belt off the power systems so can’t say if that’s right or not.
Only if it's outside the zones that is
Do they still teach you to do this at college or has it all become so anally PC its not taught anymore, we were openly taught to use this method after testing and in some cases if you forgot your meters lol....Oh how times change!!!
well that crap about an RCD being used to get round a dodgy Zs needs to go....NOT SO!! ...If anything, the over reliance of RCD devices is in the UK, and the way BS7671 has been drafted!!
Reply to Would you put a wall switch in a bathroom in the UK Electrical Forum area at ElectriciansForums.net
