Jan 20, 2012
4,122
1,135
2,688
Leeds
www.leeds-solar.co.uk
Other
If other, please explain
Solar installer for 15 years
Business Name
Leeds Solar
We're reviewing the wiring diagram format we've been using for both the customers paperwork, and more importantly the G59 applications as we're in the process of submitting an application with 8 inverters and about 20 strings of panels split across 4 roofs on it, and it's basically broken our current template as it just won't fit to any sensible size.
Looking at the wiring diagrams in BS7671, MCS, G59 engineering documents, and elsewhere, there doesn't seem to be much in the way of a uniform format to be used on the diagrams, so I wondered if it'd be possible for anyone with any good examples of wiring diagrams for above 50kW multi inverter set ups to post up a jpeg of them to see how others are doing it.
Our current diagrams are very basic line diagrams with text box descriptions of each item of equipment, labels for the cable sizes and dotted lines to mark out the roof area, inverter location, meter point etc.
These work ok for more basic set ups, but would just take up too much space for a big system, and also don't really show the protection set ups inside the inverter correctly, so would miss out the fact that the power-one has string level fusing, class 2 surge protection and integrated isolator within the inverter.
The other issue is that we've been using google docs to draw them, which is a bit restrictive on what can actually be achieved, but absolutely brilliant in terms of allowing people to collaborate on the diagrams from anywhere at the same time, so an idea of what software anyone is using to produce their diagrams would also be useful.
I'll post up some before and after shots from our current and revised efforts once I've got one knocked up using the correct symbols etc (which I think is the route I'm going down with it, if I can get google docs to play ball). I think I attempted to sort this out on photoshop a couple of years ago, then didn't save it before the computer crashed, so I gave up and just carried on using the google docs version.
We use Visio to draw ours so we are effectively unlimited on page size, our default is A2 sized though we can easily go up to A1. A lot of the plant rooms we work in have A1 drawings in folders or A2 drawings framed and on the walls already.
Standard M&E practice on new build is A1 so DNO is used to receiving drawings at that size - bearing in mind that MCS doesn't apply over 50kW and so often will have been designed and installed by an M&E contractor, they are used to getting G59 applications in that size too.
Cheers, I've now got of the team with electrical engineering degrees, so I think they're going to have to do some work to get this sorted properly rather than continuing to attempt to keep using a system more designed to be able to be understood by domestic customers.
One of the many items that's been on my to do list for far too long.
In other news, I'm trying to work out how a UK university can train up an electrical engineer without them ever having seen a copy of the BS7671 wiring regulations. I really wasn't expecting to have to send them on a specific wiring regulations course, but I kinda think it's going to have to be done.
I don't bother with drawing the string wiring on the schematics. I just write in a box number of panels and size of inverter also i submit multiple copies if more then one inverter on site . OFGEM are ok with it
interesting.
That's the approach I want to take with northern powergrid at least when just doing an application for an initial estimate of the maximum capacity to be allowed without grid upgrade costs, which I what we tend to do first.
Leeds
Website
https://www.leeds-solar.co.uk
Other
Business Name
Leeds Solar
Wiring diagrams for G59 applications - examples requested
Green Lounge (Access Only)
Gavin A,
Gavin A,
