Discuss Power used by an oven in the Electricians' Talk area at ElectriciansForums.net
Hi all,
My sister has bought an oven and has asked me to connect it when it gets delivered. She has a 6mm cable protected by a 32A mcb so I told her not to get anything higher than 7.2kW.
I've checked out the oven online and it only gives energy consumption of 0.79kWh.
From that information is there anyway of working out how many amps the oven will draw at maximum usage?
I don't think ohms law is the answer, please shed some light.
Ohmigod more like.
Either this is a wind up or someone has "forgotten" something very basic
Wattage/voltage = ?
You then do something else with the result
a 6.0mm cable on a 32A MCB will handle any cooker up to 15kW.
Diversity Diversity, Get your on site guide out page 110 or alternatively don't give up the day job, whatever that may be!
Harsh! What I find harsh re people dabbling with things they are not competent to do.
If you are an electrician then do your calculations, you have got your mcb size you have got your cable size,so work it out.
If your not an electrician then don't do electrical work.
Nothing harsh about any of that!.
[/QUOT
It's would have been better if it was really as at least he could stick his head in it and put and end to the misery.[/QUOTE]
Lol. Nice one centurion.
Bloody hell guys this is supposed to be a friendly site, I should report you all for pointless and offensive posts hahaha
... I don't know why you waste your time on here trash talking like you've never needed help before. Don't you have a regs book to read and memorise? Whatever floats your boat and gives you that semi hard on you crave I suppose!
Thanks, that's all I needed, 32A, good lord!
All you had to do was look at the specs on the beko website. Bit of common sense.
you're thinking od attraction. hungarians. won BGT.
@ OP. loads of threads on this forum about cooker diversity. use your search function.
They cant of been all the time or they wouldnt have had any diversity ;) must have been x factor sounds like diversity factor
Maybe we should all report you for a pointless and offensive question?
What do you expect from such a basic question? (One which I would of known the answer to before starting my apprenticeship!) As someone who claims to be an electrician you should know the answer to this! Maybe you should actually open up your regs book one day!
I don't have an OSG or a regs book and I didn't do an apprenticeship either, I'm not even qualified I'm just winging it lol.
If the question was so basic then why bother come on here? The original question was can you work out kW given kWh, which none of you smarty pants have answered! (I'm only referring to the cocky lot)
The energy E in kilowatt-hour (kWh) is equal to the power P in kilowatts (kW), times the time t in hours (h).
E(kWh) = P(kW) · t(h)
I could've waited until the oven was delivered and work it out myself and possibly get my sister to return the oven if the demand was too large for the already installed circuit. However because up until now I've been met by intelligent responses I thought I'd come on here instead. Jheeze! Some of you really need to chill out and stop taking things so seriously. And before you say incompetence is serious OF COURSE I'VE COME ACROSS DIVERSITY, they lost to Su Bo didn't they? Hahaha
you've even got that wreong. diversity won. susan boiler came 2nd.
I get the impression from reading through your posts that the only contribution you'll ever make to the world of electrical installation is to give it a bad name
Hahaha egg on my face! ok let's wrap it up it's been fun, need to get ready for England to lose against Italy. Now if I've got that wrong too then I will stick my head in a gas oven and end the misery lol
Well remember if you need any help working out the diversity for that, then don't hesitate to come back and ask for help as you can see we are here to help !!
Reply to Power used by an oven in the Electricians' Talk area at ElectriciansForums.net
Here is my situation We have a dedicated oven circuit in our house with a 40A RCBO We have bought a dual fuel range cooker which states it has a...
Hi, we are replacing our old hob and cooker and I need a bit of help, to make sure all is safe. This is the oven and hob specs: AEG IKB64401FB...
Hi all, looking for some clarification on MCB and cable sizes I need to run for a new kitchen. Cables will run through a combination of...
Hi all, Was wondering if anyone has come across this before and could maybe help - Its a new one to me! Customer recently altered layout of...
Hi all and please forgive me if this has been asked many times before, I'm trying to purchase and get installed by one of the national...
