Discuss 3 phase colours in the UK Electrical Forum area at ElectriciansForums.net
J
jmc1683
When you are using 3 phase colours for live neutral and earth, should you use black or grey as neutral, I usually use black as it was the old neutral colour. I work self employed for various different companies and some say you should NEVER use black as neutral, others say only use black. I always sleeve them anyway of course and I know then it doesn't really matter but what is the general opinion? I'm getting fed up of this, happened again Saturday, I was connecting coupe of swa's into board and I was connecting the blacks (sleeved blue) onto neutral bar and collegue walks in, go's, oh, didn't see that! should never use black as neutral. this is not a huge issue, no need to belittle me, just looking for opinion for discussion.
grey=neutral
Regulatory speaking it doesn't matter what colour you use for any live conductor as long as it is indicated as to its function by colour or number at every point of termination. That said, it is best practice to use grey as the neutral.
Anyone who says you 'have' to is talking nonsense, anyone who says you 'should' do is speaking sense.
I suffered an embarrassing DNO call-out over this: I thought I had voltage drop under load on a new supply, but it turned out to be that I'd wired (correctly) the DB side of an armoured as grey=neutral, black=earth but the lad I had on had wired the other end of the armoured black=neutral, then oversleeved both and I couldn't see the mistake!
well. i'd kick him for using too much of my expensive sleeving, covering all the exposed cores.
Trust me, he was well and truly kicked about in the arse dept.
Black is neutral -blue.
Grey is earth - green and yellow.
That's my way and seen this discussion on here so many times it's boring............there is NO CORRECT WAY as long as it is the same at both ends.
Dear me...............someone prove me wrong please so I can change my ways and conform !!
And who taught you that?
College tutor or guys on site?
Or regs?
I'm pretty sure i remember it being accepted "official advice" on good practice during the harmonisation period.
But you are right, as long as it's sleeved it's to regs. Just make sure the guy you work with uses the same system lol.
To be honest Andy I would normally make both ends off myself and the odd time I've had a subby working for me I make sure they know my 'preference'............then visual and testing confirms they've done it 'my way' lol :)
Yeah that's usually the case here too. Was just thinking back to a few incidents during the colour change period lol.
Being terminally colour blind, I don't care.
Mark them up as L1 L2 L3 & N.
The shiny one left over must be the cpc.
however , the problem is this......
the job im on now , ive connected new submains to main panel using black as earth.
another contractor has added cables using black as neutral.
it just doesnt look right , a bit hodge bodge.
surely after 7 years there needs to be an accepted understanding even if nothing official is written.
another pain in the --- is the fact that most 3 core cable is sold as Br/Bk/Gr which doesnt work out as clearly as Br/Bl/GY for single phase.
And then over time the numbers deteriorate or drop off and my blue and green and yellow tape unravels and we're left with a black that is actually a neutral and not a line and a grey that is actually an earth but everyone is colour blind and foreign anyway so who cares lol !!!!!!
Thank god I was trained (know you were too mate and a lot higher than me)...........trust no-one elses work.
Don't believe what you see.
Don't believe what anyone tells you.
Don't trust your test meters..............after doing all the relevant dead tests....................short everything to earth with your screwdriver or insulated spanner (turning your head away first) just to make sure their is no 'charge' there before touching it :)
anyways , wrapping this subject up before bedtime , changing UK wiring colours has been the worst change in the electrical industry for many a year in my opinion
just wish the euro would now crash & burn lol.
Al, as I said earlier today...'Don't believe anything you read' !!! :smilielol5:
Totally agree mate....................there should be no 'grey' areas so to speak.lol
But as you say when I'm terminating an swa and I have a black and a grey left over then it's a no brainer to me the black is gonna be the neutral and sleeved blue.
Reply to 3 phase colours in the UK Electrical Forum area at ElectriciansForums.net
Hi all. Yesterday I wired in my 3 phase compressor to run off our 53kva generator. I just need to know which colour cable is for which phase as...
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
Hi everyone, Quick question can you fit an RCD without any neutral connections? If I have a 3 pole circuit breaker which has all 3 poles...
Hello, I have a hypothetical question (I'm an electrical engineer) to better understand RCBOs and how they are used in the USA. Let's say I would...
Hi, I'm looking to install a new bathroom extractor fan in my bathroom as I have a windowless bathroom and the current one I have installed in...
