Lee Gold
- Reaction score
- 30
I wired 3 plate method loft light from supplying from my sisters bedroom light ceiling rose, the only way the loft light I fitted tuned on is if my sisters bedroom light was off, so then I it was really bugging me I went back to my connections supplying the loft light at my sisters ceiling rose my connections was right com from ceiling rose to switch com SL from switch to loft light, everything was fine but still the problem, I then put the live from the com in the ceiling rose into the SL in the ceiling rose seeing what will happen, I then tried the loft light, turned on my sisters light, turned off my sisters light and the loft light was operating Perfect as a normal switch would, I told her to try it the next day because it didn’t seem theoretically right that it would work normally as I connected it to the SL meaning really the loft light would only work if her light was switched on, but no it worked like a normal light switch, my sister tried it like a said the next day and it didn’t work, she then turned on her light and turned on the loft light and it worked, I turned changed the connections back from supply in sisters room from the SL back into the com, it then worked again as normal VERY CONFUSED, I then went away and said try it again she tried it and the loft light would only turn on if her light was off? Helpppppppp
