Discuss 3 way switch with black and white wires connected in the DIY Electrical Advice area at ElectriciansForums.net
tschaeff3
I have a fair amount of basic electrical experience but have never dealt with 3 way switches. I am upgrading the 1970's wiring in my attic and came across a light fixture controlled by a 3 way switch. If the 3 way switch is in the off position, the switch on the other end does not function. The ceiling junction box has a wire with the white (neutral) and ground running to the light fixture. The black wire joins two other wires running into the box with one having the black (hot) and the other wire having one of the whites connected. The hot wire from the line that supplied the white (connected to the two blacks) is connected to the light fixture. The wires power lights farther down the line. The next fixture down has the same configuration. Does this seem normal to anyone?
Could you please send some pictures it sounds like that the travelers are crossed
Reply to 3 way switch with black and white wires connected in the DIY Electrical Advice area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
Hello everyone... There are a total of 4 cables entering the junction box at the top of the staircase. Two 12/2 cables are coming in through the...
I have an outdoor light I am trying to hookup. There are two wires coming in with a white, black and ground. One is coming from the breaker and...
Trying to install a Lutron Toggle/Dimmer (TGCL-153PR) Confused, as the current switch has 3 wires gong to it Black, White, and Red (there is also...
I am adding a light fixture in a room I am restoring in my 160 yo house. I have ran a new 12-2 w/ground wire from the ceiling box to a junction...
